Starting Trouble
Hope someone can help me, I have a s2 ERST with a 1.8 ZVH, it struggles to start whether hot or cold, it turns over for ages and I need to hold the throttle down for a couple of minutes before it'll run ok, I've had the fuel and boost set up and it made no difference. If I switch the engine off even for a second it still struggles to re start, I was thinking of changing the fuel accumulator, but wanted to check on here first before I spent any money
