Different paints
Old Mar 26, 2012 | 11:24 PM
Vann1992's Avatar
Vann1992
Default Different paints
Hey, i'm not far off needing to go and buy some paint!
Question is, what will I need to paint a mk3 escort that's all pretty much back to bare metal? From start too finish.
And what type of paint, I know you get water based but don't know what type I'll need as this is my first ever attempt at bodywork.
Thanks,
Tom
Old Mar 27, 2012 | 12:12 AM
andy130's Avatar
andy130
bare metal needs to be pre wiped then etch primerd, after this you need to applie a 2K primer once you have block sanded the 2k primer your ready for base coat or 2k soild, you need to pre wipe the car again, an mask the car up ready for paint, tag rag an applie some base coat dont use water base, you need to have dryers for waterbase, tag rag between coats, once the base coat is all applied tag rag agin an applied your clear coat
Old Mar 27, 2012 | 08:32 AM
Vann1992's Avatar
Vann1992
Okay, thank you!
I'll get cellulose (how ever you spell it) basedaint then?
They do kits on eBay that has everything you need apart from the etch primer.
I'll get a link for it, could you see if it's any good?
Thanks,
Tom.
Old Mar 27, 2012 | 08:40 AM
Vann1992's Avatar
Vann1992
http://www.ebay.co.uk/itm/3901705681...#ht_2107wt_689
Here's the link for a complete kit, they do other colours but this was the first one I came across.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
