fan comin on randomly
Hi got a mate who has a 1600 focus. He said he will get init in morn n within 5 mins the fan is on hot or cold. Hes had the thermo stat changed n still the same.
Anybody got any ideas on what this could be? Cant be much can it as fan circuit is very simple?? Cheers
I had the same on a diesel one, I was having problems with the egr.i plugged a code reader in no eml on, and reset the codes and the fan worked normally, then after a while the fan would run constant,code read it again and it was egr again.
Also might be worth checking aircon system if it has it
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
