Alarm bonnet switch
Is there any way of over riding or bypassing the standard ford alarm bonnet switch,if I just disconnect the switch will it cause the alarm to go off more or just not arm the bonnet?
It's on a K reg saph
I would like to disconnect the standard alarm all together......
I would say no, you can disconnect it.
The switch is normally closed anyway, so it's the same difference to when the bonnet is down, certainly works on other alarms.
Just the bonnet won't be protected by the alarm.
Martin
Martin
are there 2 wires or 4?
if 2 disconnect it 4 tape it into the close position and hide it behind something
ps i dont know if they do have the 4 wire type but some cars do and its bad to cut em out or unplug
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
