Wanted - Series 2 pedal box
Old Feb 26, 2005 | 01:26 PM
'Eck RFC's Avatar
'Eck RFC
Default Wanted - Series 2 pedal box
I have been told I need a new pedal box and shaft for my pedal as some cowboy has hacked it to death trying to fit the wrong ratchet and clutch cable.
Is this true and if it is then does anybody have one?
The car does not select gear smoothly and crunches into reverse. also does not select 1st gear at all sometimes.
any fedback would be great help, thanks.
Old Feb 26, 2005 | 07:17 PM
nigel b's Avatar
nigel b
if you need the pedalbox it is quite a baulky item to remove..dash out job i think
crunching into reverse could be worn clutch/cable or knackered box
Old Feb 27, 2005 | 05:11 PM
ON-UJAH's Avatar
ON-UJAH
Take it to another garage for a second opinion - sounds to me like they want to rip you off. It may be a broken quadrant. One option is a Mk5 adjustable pedal, which can be modded to fit easily. Then you'll never have a broken quadrant again.
Old Feb 27, 2005 | 07:01 PM
Hartyboy's Avatar
Hartyboy
How easy is it to fit the mk5 pedal box
Old Feb 28, 2005 | 08:21 AM
ON-UJAH's Avatar
ON-UJAH
It's just the pedal you need to fit - details at the AP website.
Old Feb 28, 2005 | 12:52 PM
'Eck RFC's Avatar
'Eck RFC
The gearbox is fine, got it from DazC. The clutch cable is brand new and so is the clutch pedal ratchet as they were just fixed last week when I got the gearbox fitted.
It is jy=ust that the shaft and bushes have been abused. The Mk5 pedal seems a good idea I will look into that. Thanks folks!
Old Feb 28, 2005 | 04:58 PM
Hartyboy's Avatar
Hartyboy
What ap website is that???
Old Feb 28, 2005 | 05:32 PM
lagandi's Avatar
lagandi
http://www.apracing.com/
Old Feb 28, 2005 | 06:15 PM
Hartyboy's Avatar
Hartyboy
original
Apr 28, 2026 05:20 PM
moesin2005
Jan 23, 2022 06:28 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
adriansaleem
Aug 3, 2015 11:21 AM
