Rear is bonded on and two metal strips at back ,then you have some spot welds around the sunroof shut ,three down each side and five at the front ,ps i have a very good sunroof tray for sale btw
Yea I fancy one but if ok underneath I spend money else where for now and stu Collins seems to be eager to cut it off. So worry once done other bits I guess
Easy job did mine last week (series 2) grind spots off with a small disk and warm glue/bond up with a heat gun then it comes off pretty easily. I'm no bodywork specialist but found it streight forward enough. Got mine off twins too and was a really mint panel.
