Arrgghhhh - BASTARD ESCORT
OK, so I have just had a head skim etc, new gaskets. Put it all back together, done a comp test: 50psi, 150psi, 150psi, 150psi.
Obviously the cylinder or rings are fucked on number one.
I am beyond angry now
So, looks like I better just get myself another 1.8 zetec bottom end. Question is, which to get, do they differ too much? Do oil ways need blocking? Engineer shop job?
I need help, and fast, before I torch this fucker on the drive.
I would like a simple and concise answer on what to do next as its been 2 months now and I havent even driven the car, starting to lose faith, and just want it on the road
It refuses to fire up. It looks like I have spark, so maybe the timing is out, but am sure I have it right. I am just getting so fucked off with not having it running now
I had compression readings of 80 130 130 140 I think.
Thought it was fooked but after runnIng it, found out it was sticky valve.
Don't lose the faith yet.
Put the lighter down
OK, so was my stupid fault. I hadnt drained the lifters before putting them in.
Inlet on cyl 1 was held open a little.
All sorted and running now. Cant wait to get it booked in somewhere for a set up
Dr. Ickxs
Sep 15, 2015 10:15 PM
