mondeo going in to limp mode
Old Mar 19, 2012 | 08:09 PM
devilboy666's Avatar
devilboy666
Default mondeo going in to limp mode
hi ive got a mondeo tdci 130bhp on a 03 plate and when im driving it around 50mph it goes in to limp mode and the coil light flashes but i turn it off and back on and its fine untill 50mph again has anyone got any ideas. thanks.
Old Mar 19, 2012 | 08:12 PM
andrewg's Avatar
andrewg
Could be the start of a night mare!
You will need to get the codes read for a start
Old Mar 19, 2012 | 08:16 PM
devilboy666
i have and it says a malfunction injector
Old Mar 19, 2012 | 09:17 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Mate I fixed this very problem today on the bosses one. His is a 53 plate tdi and after testing the injectors it was that. ,408 quid plus the vat for the set but it run like a new car after fitting them and they are easy to change.
Old Mar 19, 2012 | 09:29 PM
devilboy666
hi rs did you have to code them mate.
Old Mar 19, 2012 | 09:34 PM
rs graham's Avatar
rs graham
The place he got the injectors from did it for him. His car was doin what yours is doin ! Spooky seeing you post this after the boss coming to work with this same problem this morning.
Old Mar 19, 2012 | 09:36 PM
devilboy666
yes it is mate wheres the best place to get them from
Old Mar 19, 2012 | 09:40 PM
rs graham's Avatar
rs graham
I'm down in Essex so can't help you with that.
Old Mar 19, 2012 | 09:41 PM
devilboy666
ok mate thanks
Old Mar 20, 2012 | 06:16 AM
B19 JUB's Avatar
B19 JUB
although u found the injectors were shot i reckon they have gone due to the fuel pump breaking up and clogging them up.by turning the car off it releases the pressure and hence unblocks the injector nozzles
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
