Wheel Flange Nut... XR4Ti
Anyone know where to get them??... the ones with the nylon inserts that hold the wheel flange to the axle... I need the one for the right rear... It's for an XR4Ti but I believe all 3 door, XR4i, and Saff's are the same..... Anyone has a line on them let Me know asap..... Thanx ... My car is down till I can locate one
Looking at this you get new nuts with the bearing kit
http://www.ebay.co.uk/itm/1604204377...84.m1423.l2649
Locktite thread lock might be OK if you wwant to re-use your old nuts.
I only need one nut... right rear... and I can't re-use it as it's stripped just enough to be useless...... Bearings and seals are easy to come by.... all the other nuts I can get.... right rear not so much
Karl @ FPT
Sep 21, 2015 11:17 AM
Tony W
Sep 9, 2015 12:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
