Ford Range This section is for other models in the Ford range.
MK4 Dash Removal.
Old Mar 17, 2012 | 06:27 PM
Blue-Oval-Bass's Avatar
Blue-Oval-Bass
Default MK4 Dash Removal.
I need to remove my complete dash to relocate clocks to the centre in ordrer of obtaining a better image and soundstage.
Whats the easiest way of removing the whole dash ?
Also looking for a spare bare dash.
Thanks in advance.
Old Mar 17, 2012 | 07:07 PM
hynes67's Avatar
hynes67
you will have from memory 2 on the driver's side and 2 on passenger said (where the door opens)
4 on the top of the dash between the screen
take off your steering wheel
take off your heater controls
take out your speedo
underneath the center of your dash you will have 2 screws holding the heater unit on take them out
then you will have all your heater ducting to remove from the dash
im sure thats all of the bolts/screws
Old Apr 3, 2012 | 08:09 AM
pete-si's Avatar
pete-si
There is also a 10mm bolt behind the heater controls holding the dash in
Old Apr 3, 2012 | 05:50 PM
Blue-Oval-Bass
Cheers guys , dash all out thanks.
Clock housing relocated and wirring sorted , just got to measure up and crack on with the speaker builds now.
Still on the hunt for a mk4 dash locally it poss.
Old Dec 30, 2015 | 01:08 AM
fezza99's Avatar
fezza99
Default mk4 fiesta dash removal
How long did it take you mate to remove the dash on your fez, cheers Tom
Old Oct 20, 2017 | 06:59 AM
Desy52's Avatar
Desy52
This is a very serious issue, I do not understand it very well yet. But thanks to you everything becomes clear.dqfansurvey
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
streetracer
Sep 24, 2015 08:14 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
imnoteasy
Sep 7, 2015 09:26 PM
