brakes still spongy after rear caliper bleed?
Old Mar 16, 2012 | 07:51 PM
wedge07's Avatar
wedge07
Default brakes still spongy after rear caliper bleed?
As stated, why are my brakes still spongy? Do i have to do front ones too? I swapped hoses on rears by the way?
Old Mar 16, 2012 | 08:02 PM
RUBY123's Avatar
RUBY123
yes you have to do the front ones
Old Mar 16, 2012 | 08:03 PM
Grantcos's Avatar
Grantcos
I had trouble on a car like that and it turned out air had got in to the system but I bled it do many times till I was stuck, it turned out there was a bleed nipple on the master cylinder, did that and all was well. Was a beetle btw
Old Mar 16, 2012 | 10:38 PM
studabear's Avatar
studabear
is the rear caliper mounted so that the bleed nipple is at the highest point?
Old Mar 16, 2012 | 10:39 PM
nigel b's Avatar
nigel b
if you are using cossie type calipers swing the caliper in the air to get rid of the last bit of air
Old Mar 16, 2012 | 10:53 PM
wedge07's Avatar
wedge07
Yeah i swapped the calipers around so bleed nipple was at top, im gonna bleed frobts tomoz now n hopefully shud sort it cheers guys
Old Mar 17, 2012 | 11:34 AM
wedge07's Avatar
wedge07
Been out today in car and now it sounds like pads are rubbing on passenger rear?
Originally it was doing this on drivers side until i swapoed them around and it wore pad out to metal wen other side still had 8mm of pads left? Sounds like this is goin same way??
Why is this caliper doing this??
Old Mar 17, 2012 | 11:41 AM
beaver rs 88's Avatar
beaver rs 88
in the garage
Sounds like you've got a seized caliper or slider mate. Try taking the caliper off and seeing if the pistons hard to push back. Also check the sliders are free to move in/out on the caliper carrier.
Old Mar 17, 2012 | 11:43 AM
wedge07's Avatar
wedge07
I did it yesterday and it was solid to move back? U think piston has seized?
Old Mar 17, 2012 | 12:34 PM
wedge07's Avatar
wedge07
Is it worth trying to spray wd40 between rubber n piston? Buy a new one or a repair kit?
Old Mar 17, 2012 | 05:04 PM
wedge07's Avatar
wedge07
Found prob it was carrier slider bolt seized cheers
Old Mar 17, 2012 | 05:31 PM
beaver rs 88
in the garage
glad you sorted it budd
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
