Waste oil to prevent rust?
Old Mar 16, 2012 | 06:13 PM
Fordmad!'s Avatar
Fordmad!
Default Waste oil to prevent rust?
After seeing it on a thread last night i gave it ago today!
Had some old oil in the shed after a service on my van so put it in my sprayer and filled the rails underneath until it was leaking out everywhere lol
Ruined a perfectly good sprayer in the process and thinking about it i should of just used a old washing up bottle but never mind!
Anyone else do this?
Prevents rust and gets rid of old oil both for free, result!
Old Mar 16, 2012 | 06:22 PM
BRAMMER's Avatar
BRAMMER
can't you pump wax oil in the legs, rails etc?
D16PJM's Avatar
D16PJM
only trouble is when looking in the rear veiw mirror seeing all the motorbikes hitting the deck slipping on dripping oil
never heard of this but surely wax oil must have something in it to stop it washing off as old oil won't
Old Mar 16, 2012 | 06:25 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Never heard of someone spraying it under a car! But I have known people to use it on small bits and pieces, works a treat because it effectively puts a protective film over the metal
chrisa3's Avatar
chrisa3
My mate used to fill the sills and chassis legs on his old GTEs with engine oil and just let it drip out. Bit messy, but kept the rust away.
I used this stuff on my cosworth. http://www.bilthamber.com/pro-introd...me=dynax%20S50
daz1968's Avatar
daz1968
I know someone who used to spray old oil under his car at every service seemed to hold back the rust but was very messy, not something I would do tbh, but better than nothing,
Old Mar 16, 2012 | 06:27 PM
Csm's Avatar
Csm
Mix old oil with undersealer and spray it on
Old Mar 16, 2012 | 06:29 PM
Fordmad!'s Avatar
Fordmad!
Seen it sprayed on the whole underside before but never thought about doing it. I have just repainted the whole underside of mine so didnt spray it everywhere just put it in the holes underneath.
Saves me spending a fortune on wax oil. Not much mess ass it put newspaper down first! Should keep the rust away!
Old Mar 16, 2012 | 06:40 PM
mannion's Avatar
mannion
Old Sokol technique apparently used to be quite common my grandad used to jack the car up, sowpy scrub all over then brush it on the underside of his mk2 escort with every oil change
Old Mar 16, 2012 | 06:51 PM
Chaz888's Avatar
Chaz888
Not done that on a car but old sheds yer , dryed wood soaks it all up .
Old Mar 16, 2012 | 06:55 PM
andy escos's Avatar
andy escos
waxoyl is crap i done my whole car with it & the fooking thing still rotted out new engine oil is better at getting into the joints as it is more liquid waxoyl is to thick ,&although you can heat it up to make it runny it thickens up to quick before it gets into the tight bits.
Old Mar 16, 2012 | 06:59 PM
James's Avatar
James
have heard of this before but never done it, always scared of spilling it on the seats/carpets etc! And it must smell rank for weeks afterwards?
Old Mar 16, 2012 | 07:09 PM
orionmojo's Avatar
orionmojo
As said above thats really old skool, it was more common in the 60's and 70's for sure. Obviously its totally changed now but back then the steel was shit anyway and with the cars being designed by eye rather than CAD they had mad water traps.
Old Mar 16, 2012 | 07:15 PM
Fordmad!'s Avatar
Fordmad!
Obviously i didnt do it inside the car Lol
Only did it in the rails and sills! Ive used wax oil and its shite so i thought id try it and aslong as you make sure i don't go everywhere i reckon it'll work! Going to use a squeezy bottle next time think it'll work better! Wouldnt spray it over the whole underneath though as it'll look terrible
Old Mar 16, 2012 | 07:18 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
on a typical cossie, the engine sprays oil on the underside for you.
Old Mar 16, 2012 | 07:20 PM
James's Avatar
James
They still do, new cars might have shiney plastic arch liners but nearly always theres a corner full off mud & shit! They just dont rust out as metel & paint is so much better now.
Old Mar 16, 2012 | 07:21 PM
Fordmad!'s Avatar
Fordmad!
Haha LOL
Old Mar 16, 2012 | 07:54 PM
orionmojo's Avatar
orionmojo
Well yeah, thats all true. You dont see as many 10 year old cars now with the arches and sills hanging off them, back in 2000 how many mk4 escorts and mk3 astras were rotton as hell
Old Mar 16, 2012 | 09:22 PM
KregRS's Avatar
KregRS
I used to know an old boy years ago, self employed mechanic, never threw out waste oil, used to keep it and use it like that. From what I can remember, he was quite slow at his job, but very thorough, never cut corners, and was an absolute genius with an auto box.
Old Mar 16, 2012 | 09:36 PM
MAD Ade's Avatar
MAD Ade
You spray the underside of the car OUTSIDE you plank...
Old Mar 16, 2012 | 09:43 PM
sharky584's Avatar
sharky584
Shark conversions
made me chuckle...
Old Mar 16, 2012 | 09:48 PM
Fezman1's Avatar
Fezman1
As said old skool method. Farmers use it to stop ploughs etc rusting in storage.
You have to be careful fuckin about with old oil tho - carcinogenic risks.
Old Mar 16, 2012 | 09:50 PM
Eagle's Avatar
Eagle
Super Moderator
i owned a ford ... it sprayed its own bloody oil under the car ! ! !
Old Mar 16, 2012 | 10:25 PM
stuboy's Avatar
stuboy
ford transits tooo
Old Mar 16, 2012 | 10:34 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Originally Posted by stuboy
ford transits tooo
Same engines though aren't they??
Cheers,
Grant
Old Mar 16, 2012 | 10:36 PM
stuboy's Avatar
stuboy
Cheers,
Grant
diff last longer on transits
Old Mar 16, 2012 | 10:40 PM
RS Grant's Avatar
RS Grant
Made in Scotland
True story.
Cheers,
Grant
Old Mar 17, 2012 | 08:11 AM
Fordmad!'s Avatar
Fordmad!
It must stop rust as good as anything out there you can buy then!
Old Mar 17, 2012 | 08:38 AM
GINGExR2 T's Avatar
GINGExR2 T
As said, Waxoil, even when warmed up still sets to fast, Was thinking of spraying new clean oil down my sills etc, at least it'll run around the spotwelded areas.
Will clean new oil mix with Waxoil??? might keep it moreof a liquid for longer.
Ginger
Old Mar 17, 2012 | 09:02 AM
Fordmad!'s Avatar
Fordmad!
Id just use oil tbh. Buy some cheap stuff! Though even though the underneath of mycar is clean as ive painted it using waste oil really wasnt that messy tbh so will definatly be doing it again.
Still have loads left so will probably do it every few months!
Old Mar 20, 2012 | 07:25 PM
Fordmad!'s Avatar
Fordmad!
May fill my sills now as it looks a good job everywhere else ive done!
Old Mar 20, 2012 | 07:32 PM
Ginger Will's Avatar
Ginger Will
Don't want to piss on anyone's parade but, doesn't this pose a huge fire risk as the oil could go up like a fucker if there was a problem. Say in future you need a sill welded it could ignite and set fire to the whole car.
I could just be being overly cautious.
Old Mar 20, 2012 | 08:47 PM
Dennis_Wiseman's Avatar
Dennis_Wiseman
No because oil isn't 'highly' flammable plus once you coat oil on the actual raw oil of it tends to vanish off so your left with just a water proof coating
Old Mar 20, 2012 | 08:52 PM
gjh's Avatar
gjh
Its an old skool thing my dad still does, the underside of his car is in good nick so, it might be working, can be a little messy, but it seems ok. If your going to weld a car underneath afetr doing so you need to clean the area properly before welding.
Old Mar 21, 2012 | 06:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
used oil is acidic so i wouldn't use it.
also, good point raised about motorcyclists slipping on it - there's enough hazards on the road through diesel spillage without adding old engine oil slopping out of your sills to the equation
Old Mar 21, 2012 | 07:47 AM
Fordmad!'s Avatar
Fordmad!
Tbh aslong as you left it to drain long enough it wouldnt spill on the road.
After everyones views im personally going to keep doing it as old ways are usually the best!
Old Apr 3, 2012 | 07:30 PM
MAD Ade's Avatar
MAD Ade
The old oil has carbon in it which helps as a neutraliser on early signs of corrosion.
Old Apr 3, 2012 | 08:51 PM
Vann1992's Avatar
Vann1992
They use it for truck leaf springs, supposed to keep em flexible and less brittle.
I've done it a couple times on older cars, but Not on a newish motor.
Old Apr 4, 2012 | 04:28 AM
My dad and grandad used to do this.
Old Apr 4, 2012 | 06:42 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
It's insane! WTF!
