4x108 to 5x110 or 5x108 escort mk3 help needed
hi guys i need to change my stud pattern from 4x108 to 5x110 or 5x108 can anyone tell me were i can get hub adaptors from or wot ford can i swop a mk3 escort from to get 5x108 or 5x110 with out to much hassle cheers
now fella ,
i dont think theres anything else in the ford range that will fit the mk three
imo the best thing to do would be to remove the flanges and take them to a local engineers and have them welded up and redrilled to 5x108 , youd have to see if theres enough meat on them for 110 ,
or , depending on the offset of the wheels your looking at , have them machine you up custom 10 mm spacers .
hope this helps
hope this helps
now fella ,
hope this helps
hope this helps
muz
Aug 16, 2015 12:57 PM
