Wheels and Tyres Wheels and Tyres for all Ford's
Wheel offset
Old Mar 13, 2012 | 10:46 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Default Wheel offset
If you have two wheels and one has an offset of ET35 and the other ET40 am I right in thinking that the ET35 will stick out more from the hub?
If that is correct can I simply use a wheel spacer to make up the difference?
If so which size / how thick?
Or have I got this completely wrong
Old Mar 14, 2012 | 02:26 AM
mk22door's Avatar
mk22door
Bumped.
Old Mar 14, 2012 | 03:28 PM
mk22door's Avatar
mk22door
Bump to the top.
Old Mar 15, 2012 | 08:04 PM
mk22door's Avatar
mk22door
Anyone please????
Old Mar 15, 2012 | 08:23 PM
phil_rs's Avatar
phil_rs
yam yammer
Yes a ET35 will stick out further than a ET40. If you use a 5mm spacer on a ET40 wheel, it will be equal to ET35
Old Mar 15, 2012 | 08:39 PM
mk22door's Avatar
mk22door
That's fucking banging!
A REPLY!
Cheers, that's what I thought thank you very much phil69a
Old Mar 15, 2012 | 08:41 PM
mk22door's Avatar
mk22door
Oh, by the way phil, who makes precision spacers please?
Old Mar 15, 2012 | 09:15 PM
phil_rs's Avatar
phil_rs
yam yammer
Not a problem buddy, this is what passionford is all about
I have no idea, I'm sure any spacer will be just fine mate
Old Mar 17, 2012 | 05:52 AM
davstt's Avatar
davstt
using just a standard 5mm will be fine as your hub should stick out and locate your wheel any bigger and you would need hubcentric spacers .just type it into bgay to see loads of different sizes. could go 15 one side and 20 other make them even wider ,but would work out pricey .
Old Mar 20, 2012 | 03:03 AM
mk22door's Avatar
mk22door
Thanks for the advice
bgay
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
