Escort RS Turbo build - E444
Old Mar 13, 2012 | 09:34 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Escort RS Turbo build - E444
Its about time i started a build thread i spose so here we go...
I bought the car about 2 years ago. it had a rebuilt standard 2 litre silvertop zetec apart from 1mm skimmed pistons (to lower compression), stage 2 T3 on cvh manifold, rover turbo inlet manifold, alloy rad, bigger intercooler, omex 600, oil cooler, deisel box with rst lsd
Prinout for 254bhp at 14psi. But i turned it down to 11psi.
willwood saph front brakes
saph rear brakes
inline brake pipes with bias controller
uprated shocks and lowering springs
front strut brace
full cage
sparco bucket seats and harnesses
various gauges
The engine had been build on a low budget, so like most zetec turbo on standard internals, it died! Well, it started to smoke and had a loss of power.
I sold the car as it was to P33PRK from on here (i think)
However... about a year later i wanted it back so after a few txts it was on its way back as he was on about selling it anyway.
He replaced the turbo to hopefully cure the problems but it was still the same. When i got it back i thought i may aswell start again and build it properly. First i took the head off just to see what was going on inside, and this is what happened.
Commonly know as... Blown to the bone.
So i took that engine out and binned it, and started again with a doner engine from an automatic mondeo.
First i bought some 1mm oversized forged low comp turbo Wossner pistons and PEC rods.
Then i had the block bored
Then built the bottom end.
Then bought new oil and water pumps
Then i started the head, which was very time consuming! I still wanted to use the Rover Turbo inlet so i had an adaptor plate made. Then i filled the zetec injector cut-outs with ally weld, then bolted the plate to the head and matched the head to the plate, and ported and polished the inlet side
Then i had 3 angle valve seats cut (and valves re-faced)
So now the engine is pretty much done. Ive also decided to use a Focus RS gearbox. Luckily i found a package on ebay- which consisted of the gearbox, driveshafts made to fit a mk4 escort, clutch, flywheel, starter motor, gear selector cables and electric speedo.
Then i had a go at mounting it...
First i mounted the engine and box together and dropped it in the engine bay where i wanted it. I mounted the engine side, then made a bracket on the inner wing for the top gearbox mount.
And thats as far as ive got really. The clutch and flywheel are on the enine and the engine is bolted to the box.
Next job is to modify my clutch peddle for the clutch master cylinder then drop the engine in, then put everything back on.
I also got fed up of the cvh manifold adaptor plate blowing so i bought a 2nd hand Focus RS Exhaust manifold, turbo and down pipe.
Il use this for now, then mabey upgrade to a hybrid GT28 and Ford Motorsport Manifold next year.
My aim is to get it built, run in and mapped for RS Central day next month but cant see it realisticly happening at the moment!
Since i got the car back i also painted the wheels and vents black for when its done.
Old Mar 13, 2012 | 09:56 PM
little bram's Avatar
little bram
looks really good mate am liking it what you doing about your drive shafts?
Old Mar 13, 2012 | 10:00 PM
TomPengelly
Kapow!!
Cheers mate. When i bought the gearbox,it was previously in a mk4 escort so a pair of custom shafts to fit were included.
Old Nov 18, 2012 | 07:31 PM
TomPengelly
Kapow!!
I forgot i made this thread! Well the gt25 idea soon went out the window... I went for a T4 turbo with external wastegate and suitable injectors (cant remember what they are)
Also uprated the valve springs from the peugeot items to some zetec turbo ones from Devil Devolopments.
Il give it a go, if its really laggy mabey il get a gt30 afterwards. Ive also had a manifold made by crazycage. Massive thanks to him!
Ive also got my coilovers now, (big thanks to weeksy) and am getting focus rs brembos next week for the front.
Ive also bought an intercooler from Stuart Colins that should do the job.
The car is currently a shell, being prepped for a respray.
Think ive decided on Ferrari Silverstone Grey with black wheels and cage.
also massive thanks to Ryan (s2erst) for doing an amazing job repairing and flocking my dash and gauge pods. Looks the nuts!
So when the things painted, il get updating. Not too far to go till its finished now really!
Old Nov 18, 2012 | 07:51 PM
TomPengelly
Kapow!!
H yeah, also... I didnt like the look of the mount that i made so started again, with the help from Crazycage again!
Top one:
And the bottom one... Its homemade but should do the job.
Old Nov 18, 2012 | 08:34 PM
turbo m's Avatar
turbo m
Cracking project.
Did it once belong to dan savage??When it was in pf mag with lewis[high towers] black zt rst???
Old Nov 18, 2012 | 08:42 PM
TomPengelly
Kapow!!
Nah not this one mate, Jason Pillinger, the owner before me converted it to zt from a standard car i think.
Old Nov 18, 2012 | 08:52 PM
Good to see a thread on the car Tom
Old Nov 18, 2012 | 08:56 PM
TomPengelly
Kapow!!
Cheers. When its painted il get some photos of the bumper, mirrors and scoop up that you sorted me out with. Massive thanks to you too for that!
Old Nov 18, 2012 | 09:06 PM
Danster76's Avatar
Danster76
Nice one Tom its coming together. Pop round sometime.
Old Nov 18, 2012 | 09:23 PM
TomPengelly
Kapow!!
Hi Dan, yeah i will soon, been so busy lately. Probably be this weekend if not the next one. Cheers.
Old Nov 18, 2012 | 09:24 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Fair play tom, ill be up your way when you get it back! Top worrk so far
Old Nov 18, 2012 | 09:40 PM
TomPengelly
Kapow!!
Yeah mate no probs. Cheers!
Old Nov 19, 2012 | 06:40 PM
crazycage's Avatar
crazycage
looking forward to seeing all built up .
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
