painint rocker cover!
Old Mar 10, 2012 | 05:00 PM
PETEDUDE007's Avatar
PETEDUDE007
Default painint rocker cover!
eventually id like to get this powder coated but ill wait til i have a few items to send in together!
so short term im going to paint it!
whats the best way to prep it for paint,what primers etc does it all have to be heat resistant or can i use a heat resistant primer and then regular car paint or..........
Old Mar 10, 2012 | 05:05 PM
Maxwell's Avatar
Maxwell
Irregular Poster
Why waste your time prepping and painting, when you can have it powdercoated for around £15?
Old Mar 10, 2012 | 07:10 PM
simonmcf's Avatar
simonmcf
Is it not dodgy getting it power coated? I know lads that have got Honda rocker covers powered and ended in engine problems?
Old Mar 10, 2012 | 07:37 PM
Sjieter's Avatar
Sjieter
maybe they had the inside powdercoated too which isnt what you want. if you powdercoat the outside you are good to go, wont get you any problems.
The paint on the inside flakes of and blocks oilways
Old Mar 11, 2012 | 04:02 PM
essexRSTSouthend's Avatar
essexRSTSouthend
I'm experienced powder coater for over 6 years. Don't do any prep work apart from rubbing it down and even then that should be the companys job. They will use a pretreatment that treats the metal before bonding the powder
Old Mar 11, 2012 | 04:08 PM
Fordmad!'s Avatar
Fordmad!
I used nitromores on mine as it had been sprayed before. Cleaned it up and gave it a light sand. Used high temp spray and then a few coats of high temp laquer.
For the cost and hassle just get it powdercoated!
Old Mar 11, 2012 | 07:24 PM
bigkev's Avatar
bigkev
i,ve got a rocker cover powdered white in the garage, looks good, I dont use it as ghot 1600i rocker cover on mine now
Old Mar 12, 2012 | 12:14 AM
PETEDUDE007
maybe u will hae to pt up a pic of it kev might buy it off ye!
Old Mar 13, 2012 | 09:02 PM
bigkev's Avatar
bigkev
i will do, pm me
Old Mar 16, 2012 | 03:41 AM
tejy's Avatar
tejy
Hi mate saw that you wanted to paint your rocker cover, I done mine not too long ago.
This is how my bay was looking before I started buftying it up.
I stripped down the old paint using a wire brush drill bit which cost me like £4.. and used 180 grit wet and dry paper to prep the hard to reach bits
I then used etch primer in a can for a base coat - Cost me around £8
Used a touch up gun as it covers a smaller surface area
Then came base coat
And the laquer
Heres a few pics of it finished
Etch primer is fine to use, it sticks to the metal nice and you can get it smooth before you put down your basecoat. You dont NEED to lacquer it but I did it because its easier to clean and it makes the paint finish look much shiner!
Hope this helps!
Old Mar 16, 2012 | 08:57 AM
Fordmad!'s Avatar
Fordmad!
If you don't laquer it then it'll just get dirty real easy!
Old Mar 16, 2012 | 06:18 PM
PETEDUDE007
well i started it today! dont know if ill bother with lacquer! as i do plan to powder copat that and other bits down the line i just had a few days off work so thought id do it coz ive not got much else to do!
Old Mar 16, 2012 | 06:38 PM
Fordmad!'s Avatar
Fordmad!
For the cost of laquer do it and if done right won't need powdercoating
Old Mar 17, 2012 | 01:13 AM
PETEDUDE007
Ok nuff said lacquering it tomorrow!
Old Mar 17, 2012 | 01:37 AM
tejy's Avatar
tejy
Very true mate.
Get some pics up! What colour will you be painting it? The colour that I used was Mercedes blue black, it was just some leftover paint my mate had! Come out really nice though.. Well I like it
Old Mar 17, 2012 | 01:56 PM
PETEDUDE007
WELL ITS NOT THE BEST JOB IN THE WORLD. i just used a black hight temp paint! the finish is rank! tbh but ill be doin it again! pics up soon! i also want advice on some other things with tarting up my bay! coz i dont want to be too blingy! i have an idea in mind tho!
Mark RS
Mar 5, 2021 06:08 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fil
Sep 30, 2015 12:08 PM
deathrider666
Sep 28, 2015 06:12 PM
