Fiesta Idling Problem,
Old Mar 8, 2012 | 06:44 PM
ADT168's Avatar
ADT168
Default Fiesta Idling Problem,
Hi people,
I have a Ford Fiesta 1.4 zetec,petrol, 2003, 64,000 miles,
The problem i have is starting from cold,
The car will not idle and cuts out, if you hold the throttle it will idle ok till its warm,
once warm the car is ok,
If you pull away when it is cold, you will get to a junction and it will cut out,
the car does not run lumpy just cuts out,
i have had the car plugged in to a diagnostic machine, (no codes)
I have cleaned the throttle body, cleaned the map sensor,changed the fuel regulator,
and changed the fuel filter to a original ford one,
I just dont know what to do next
Has anyone had this problem and found the cure?
Any info would be appreciated,
Regards ash
Old Mar 10, 2012 | 02:17 PM
ADT168's Avatar
ADT168
I think i have found the fault people,
the crankcase breather pipe has a split on it
Old Mar 10, 2012 | 08:14 PM
Have you replaces that pipe.Has it cured it.I know the idle speed control valves go faulty on these engines.It should be on your inlet manifold.
Old Mar 11, 2012 | 05:43 AM
B19 JUB's Avatar
B19 JUB
if its a mk6 fiesta im sure its incorporated in the throttle body
Old Mar 11, 2012 | 10:06 AM
ADT168's Avatar
ADT168
I have got a replacement pipe and fitted it, it seems to be ok now,
I think the idle control is incorporated in the throttle bodie as b19 jub has said.
Thanks for the replys people,
Old Nov 27, 2012 | 03:43 PM
westy32's Avatar
westy32
Hi I Have this same problem i'll try the pipe is it the one from the rcoker box to the air filter? or one of the plastic ones??
Old Nov 27, 2012 | 04:15 PM
the_frozen_one's Avatar
the_frozen_one
It's whichever one is split D
Old Nov 27, 2012 | 06:44 PM
westy32's Avatar
westy32
found it now its split too will get it replaced now
Old Nov 28, 2012 | 04:42 PM
westy32's Avatar
westy32
is there anywhere online to buy ford parts??
Old Nov 28, 2012 | 04:51 PM
Bailes1992's Avatar
Bailes1992
This is a common problem, had it on my Focus. Copied a previous post I made about it...
Part number from ford is FMU 1337254 and I paid £12.15 for it.
The hose just pulls off, I removed the idle speed control valve (and if you have it) the wiring going to the MAP sensor.
A little bit of oil on each end of the hose to push it on and some patients. Will go on eventually.
This is a picture I took showing everything I removed
Think I've named it all.
Have fun
Old Jun 20, 2015 | 09:48 PM
Red_bullet's Avatar
Red_bullet
Thumbs up @006 Fiesta will not start sometimes, will not idle FIXED
Ford Fiesta zetec will not start, will not idle. Ford Fiesta 2006 zetec will not start, will not idle.
Read on, the answer is at the end of this post.
Ford Fiesta: I am experiencing starting problems with my ford
I am experiencing starting problems with my ford fiesta Zetec 5 door hatchback 2006, 5speed manual. The car
has done about 60000 Kms. sometimes you turn the ignition key and it start first time, other times it seems
to start but doesn't maintain an idle an cuts out again. When this happens it sometimes starts the second
time but increasingly of late has then not started after several more attempts and you need to wait a minute
or so and try again. Sometimes it seems to help by turning the ignition key the first couple of clicks, so
that he lights on the dash come on but you haven't actually turned the engine over, and then after a couple
of seconds you then turn the key over fully, hold it over for a second or so and then release it - and the
engine stays on. Whether it is a cold or warm start doesn't seem to make a difference with this starting
problem. We make sure we do NOT depress the accelerator pedal when starting.
My mechanic also recently replaced the spark plugs with titanium ones, I think, as designated in the service
manual but the problem occurred before he did so and hasn't made a difference either way.
The problem does seem to occur more often now ... Over the course of several months.
Any ideas? Has anyone heard of this sort of problem and any solution? Many thanks for any help.
The fix is, battery voltage goes low during cranking making ECU malfunction thus not allowing car to start
correctly. Replace the battery.
(Battery voltage can go as low as 7.5 volts under load and it still cranks over fine, but voltage is too low for the ECU to operate correctly.)
Old Jul 27, 2020 | 05:19 PM
Bails's Avatar
Bails
What is the name of the pipe needed or the part nunber, my lads car has the same problem and all symptoms sound the same, was going to replace the idle valve control, but think this pipe may be the problem.
rex647
Mar 6, 2022 06:20 AM
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
