cosworth brake servo help...now sorted
Right iv got a cosworth servo on my focos im bilding and i will be running it with out the ABS unit so im only running the brake pipes off the servo there are 3 ports on the servo iv been told to put the front brakes on the front port and run the rear brakes off the rear port and blank the center port off well the problem im having is im using a brake bleed kit that puts 30psi in the pipes so the front brakes bleed up in two min but nuthing coming out of the rear i even hit the foot brake but still no good so i undid the pipe on the rear port and i should of had brake fluid coming out of it at about 30psi well not a drop but when i undo the center port i get brake fluid coming out out of it . has any one done this mod befor and which ports did you use on the servo .
Right its now sorted as my good mate Dave came round tonight and he has a spair servo so we got my one off the car and put the new one on and after bleeding the brakes two times its spot on it turns out there is some thing rong with my servo so i will be stripping it down to see wots gone rong with . thanks to warrenpenalver for helping with some info
Aug 14, 2015 07:29 AM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
