heat wrapping 4x4 manifold
Old Mar 5, 2012 | 04:04 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Default heat wrapping 4x4 manifold
Ive recently wrapped my downpipe and made a heatshield which has knocked my ACT's down a good 15-20 degrees about town.
Is there any reason not to wrap the exhaust manifold??
Old Mar 5, 2012 | 07:12 PM
DAN400's Avatar
DAN400
are 4x4 manifolds not prone to cracking?
imo wrapping it would make even more prone to cracking as your keeping the heat in it
Old Mar 5, 2012 | 08:19 PM
Psycho Warren
Carbon Crazy
are they that bad???
Old Mar 5, 2012 | 08:23 PM
cutch's Avatar
cutch
Series 1 4x4 cossie
hmm i wouldnt mind knowing this too, I was going to wrap mine but i didnt know about the cracking problems?
Old Mar 5, 2012 | 09:10 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
surely cracks are from expansion and contraction yes?
then surely contraction would be less if the heat was kept in when wrapped?
Chip or someone else with more of a pulsating brain got any input, id be interested to see if my theory was utter horse crap or some legitemacy in there
Old Mar 5, 2012 | 09:15 PM
The Youth.'s Avatar
The Youth.
the cracking is always at the same point on the wall/ webbing opposite the mouth on the entrance to the turbo, it has to be the heat generated at the small area causing it.
steve
Old Mar 5, 2012 | 09:20 PM
Cossie Sean
interesting, ive never owned a 4x4 manifold, let alone a cracked one so never seen this, but principles for most manifolds agree steve,
all Audi 5 pot manifolds ive had to change, 4 so far, have all gone in the same place on my A4, again just before the entrance mouth!
Old Mar 5, 2012 | 10:11 PM
Red16's Avatar
Red16
I wrapped the exhaust manifold on my turbo ZX10R engine using Thermo-Tec Generation II Copper wrap and it has gone all dry and brittle and began to fall off, after only a few hundred miles, not overly impressed with that! Although the downpipe/exhaust are still fine.
It worked wonders for the under bonnet temps though, the wrap felt like a household central heating radiator when the engine etc was at full temperature.
Old Mar 6, 2012 | 07:56 AM
DAN-Saff's Avatar
DAN-Saff
Have you checked there isn't a silicone hardener for the wrap that your supposed to use? The dei stuff usually does.
Old Mar 6, 2012 | 08:14 AM
Red16's Avatar
Red16
I used this wrap
and coated it with this once it was wrapped onto the exhaust/manifold
The finished article before it dried out, went brittle and began to fall off on its own
This is the exhaust, which is still in perfect condition
Feel free to give any more feedback
Old Mar 6, 2012 | 09:54 AM
DAN-Saff's Avatar
DAN-Saff
You've used the right stuff it looks like you didn't saturate the manifold enough as its got multiple layers. The only reason I say that is that you can see the colour of the wrap.
And did you wet it before you fitted it? With the normal stuff you can lay it tighter if you wet it first.
Very neat tho I can never get it to look neat
Old Mar 6, 2012 | 11:20 AM
stu21t's Avatar
stu21t
I used cheap shitty wrap and a can of hi temp paint on my 2wd manifold.
It did wonders for underbonnet temps, you could actually hold the manifold after a run whereas before if you looked at it it would burn you.
It was on there for a couple of years and didnt crack, it did start to perish so i took it off and had the manifold ceramic coated inside and out.
This is nowhere near as good in my car so i will be re wrapping it with carbon wrap.
I did also wrap my whole exhaust system up to the back boxes with the same stuff, this didnt perish but did cause the exhaust to crack on a Y join, where it split fom 1 to 2 pipes on the sharpest point it cracked.
I will redo this aswell and not sure what i will do with that section as it will just crack again.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
cossie09
Sep 10, 2015 06:56 PM
