Mk1 sierra et38
Im pretty sure the standard offset for the 15's is et38 so yes. Are TS7's 7 inch. You should be fine.
Ive got 7.5 (et30) front and 8's (et25) rear. You could probably go much lower offset unless you want to keep the standard sucked under look.
nico12
Dec 31, 2015 04:42 PM
