Focus mk1 inlet manifold removal
Resident Camel Stalker
How is the inlet manifold removed? Also a pic of where the bolts are located would be excellent. Need to change my iscv over so inlet needs to come off
You can reach it from underneath, you need long arms and a 1/4" drive socket set.
Ideally on a ramp so you can stand up and reach straight up, your working by feel though as its not easy to see.
What problem are you having with the car
Easy to do but fiddly, you can gain access to the top one from above and bottom from underneath, just as fiddly as removing the inlet manifold as youve got 4 or so bolts to gain access to underneath the manifold.
Anutternutter
Aug 21, 2015 06:07 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
