Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
lowering focus st170 on springs will it be ok
Old Mar 2, 2012 | 11:45 PM
st170danny's Avatar
st170danny
Unhappy lowering focus st170 on springs will it be ok
hi i have a st 170 it handles really good but i want it to be a bit lower so i want to put some 40 mm lowering springs on it but im worried this will ruin the way it handles just wondering if it will still be ok?? .thanks
Old Mar 3, 2012 | 09:18 AM
thebigmacmoomin's Avatar
thebigmacmoomin
I was always told taht any lower than about 30mm, you may need new dampers aswell. I just lowered both my Mk1 Focus's on Eibach springs, which is 30mm.
Old Apr 11, 2012 | 09:52 PM
caljones92's Avatar
caljones92
I heard about new dampers as well but others also told me it would be fine so I dropped my focus 50mm from standard on all the standard shocks and stuff and it's fine... Just a bit stiff! Hasn't had any effect on handling whatsoever so you should be fine.
Old Apr 29, 2012 | 05:57 PM
siany1997's Avatar
siany1997
If you go too low, you'll find the suspension travel on the shock is reduced to a point where its not effective. Really go low, and you end up a point where the shock is effectively solid, and if you hit a bump or an undulation at speed, instead of soaking it up, the wheel will just bounce. Wheels on the ground are good for grip
30mm should be ok. 50 mm less so.
Old Nov 30, 2017 | 09:44 AM
marcus.st170's Avatar
marcus.st170
Unhappy
hi, new to the site, and new to the ford scene. apologies if im replying to a really old post, but have you any pictures of your car on its 30mm springs, so i can get an idea of what i want to do.
thank you for your time
Old Dec 2, 2017 | 10:58 AM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Old thread, might be best to start a new one.
Just to give an idea what 30mm looks like.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
