Lots of 4x4 & 2WD Saph parts *UPDATED 03/03*
Various parts for sale off my saphs
REAR HUBS £20 pair
SETS OF USED FRONT TCAs £10 PAIR
BLACK CARPET £20
4X4 REAR BEAM £25
ALLOY INTERCOOLER (UNKNOWN BRAND) £50
4X4 FRONT BRAKES with very good pads possibly EBC greenstuff and barely worn discs, Now want £60 with the pads and discs as a set
4X4 REAR DRIVESHAFTS VGC £40 PAIR
4X4 KONIS with springs £125
4X4 REAR DIFF PAINTED SILVER £80
4X4 ABS ECU £15
4X4 POWER STEERING RACK £30
STANDARD PAS TANK £5
PACE RS500 STYLE INTERCOOLER (VERY TIRED BUT STILL WORKS) £70
FULL SIDE GLASS SET (CAN SPLIT) £5 per window
BOOTLID WITH SPOILER IN WHITE £40
NSF DOOR IN WHITE £20
NSR DOOR IN WHITE £20
REAR LIGHTS £20 PAIR - CORNER BROKEN AWAY ON OFF SIDE
MAGNEX OE SPEC STAINLESS EXHAUST SYSTEM £150 (RETAIL AT £750 NEW) WILL CLEAN UP EASY
PLASTIC SCUTTLE PANEL £10
4X4 FRONT ARB £10
4X4 FRONT SUBFRAME £20
BLACK LEATHER FRONT AND REAR SEATS WITH DOOR CARDS, REASONABLE CONDITION, usual shrinkage to door cards and bolster wear otherwise good £175
Please ask for any other parts you may need. Located in Norwich but will post smaller items. Also visit Northampton area quite often if that's any closer to you?
Pics in progress!
REAR HUBS £20 pair
BLACK CARPET £20
4X4 REAR BEAM £25
4X4 ABS ECU £15
4X4 FRONT ARB £10
Pics in progress!
Mungus - YHPM
Matt Baxter - Heatshield in pictures below...door mouldings are in pretty good nick, can get pics after the weekend.
Shings - sorry no spare FPRs
BIG TONY RS - YHPM
BIG TONY RS - YHPM
Can you send the rear arms to Holland? I don't mind the extra costs as I suppose the weight will be a bit high. And if the header tank is not sold yet I'd also like that.
Am interested in the bootlid if paint is good enough to fit as is and the spoiler mountings are perfect? ie bolts not rusted through from the bootlid if that makes sense? Can you post this though as you are too far for me to collect? If so, can you get me a total cost delivered please to BH postcode?
cheeRS
cheeRS
cossiedad - Bootlid paint is good enough to fit and should be able to leave the badges on providing I can find the spares I have(see pic taken a month ago). The outside mountings are perfect but the centre one is a little suspect from memory, will look into this. Not sure I am able to post an item that large to be honest though. Let me know if you are able to collect, Could take to Northampton with me one weekend if that helps at all?
cosimworthit - Hi mate, I think the splitter may well be sold already but I will let you know. Will put your name against the front bumper and bonnet now as per our conversation. Cheers
Marc sierra - Ok cool, swirl pot was removed before I bought the car unfortunately.
phil2002 - in talks with someone about the splitter at the mo, then have a second person in line. Will let you know if neither have it, cheers
tomoyb - Ok, no probs. I am available after 6pm weekdays or any time weekends for courier collection only though. If you want to arrange a courier just let me know a couple of days in advance so I can box them up. Please confirm by PM and I will send paypal address. Cheers
All PMs replied to. Parts sold will be updated this evening. Pics and postage quotes early next week. Also I may have a set of Rs soft spoke 17s available in good condition with good tyres £400
Brad
Brad
Glenn - PM'd you earlier
Harris - sorry header tank is sold
Toe Knee - yes it is, colour is dark grey/black in good condition. £22 posted due to size
scoobypete - sorry I don't have a 2wd pas rack for sale
scoobypete - I have the following 'rear end' parts although I am currently in conversations with others about a couple of them. Best to let me know what you want from this list. Also, I'm located in Norwich but do visit Northampton occassionally at weekends if that helps?
2WD REAR BRAKES INC GOOD USED DRILLED DISCS AND USED PADS
4X4 REAR DIFF
4X4 REAR BEAM
4X4 PROP
4X4 DRIVESHAFTS
REAR HUBS
REAR ARMS
4X4 REAR DIFF
4X4 REAR BEAM
4X4 PROP
4X4 DRIVESHAFTS
REAR HUBS
REAR ARMS
