My Garage and Workshop
Here is the current state of my parents driveway, all the cars in shot are mine (my dad has to park on the neighbours drive when im at home.
Driveway; Got my cossie shell under a cover
Garage and Workshop; My Mk3 Fiesta is currently in the garage just got the bodykit to finish spraying and then cossie shell can go in
Garage;
Workshop;
Workshop has a concrete base, and then a couple of rows of bricks with wooden stud work on top, its fully insulated and is boarded out inside, the front doors open out further to give me a double opening. Will get more shots next weekend as need to give it a good clear out as I should be picking up a lathe to go in there
One of my Ghia Automatic; brought this to store all my Cossie parts while I rebuild it, I have now decided to use this as a test bed so Im currently getting it all wired and plumbed in with the cossie stuff so I can run it round and sort out all the annoying issues.
Garage;
Workshop;
Few more pics of the front;
Got an outside socket, Connected to my charger, I can then run a cable from the car to the outside socket without having to worry about trapping the cable in the door;
Had to have a tidy up today as I picked up a lathe, needs some restoration but I managed to pick it up cheap.
Got to sort out our spare bench now as currently its now stored in the workshop until we decide what to do with it.
It doesn't output 110v we had a 110v socket lying around so put that on and wired some 3 core to a 240 v socket inside. The charger connects to the 240v socket and I then have a lead I use outside which has a 110v plug on one end and an Anderson jack on the other.
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
