Frst rear disc conversion best way to do it?
Old Feb 18, 2012 | 09:34 PM
chrisxr2it3's Avatar
chrisxr2it3
Default Frst rear disc conversion best way to do it?
I'm looking to fit rear discs to my fiesta an heard theirs a few ways to do,fiesta centre kit or fit focus rear hubs by elongating the holes in the frst beam or fitting Zetec s beam ?also will the standard bias valves be ok or would I need an adjustable bias valve fitted What way would u suggest thanks in advance
Chris
Old Feb 19, 2012 | 08:28 AM
shalon's Avatar
shalon
Use the mk5 fiesta axle n focus set up rs2000 hand brake cable then put ka inline bias valves just before the flexi thats what I done all parts reasonably priced and readily available
Old Feb 19, 2012 | 01:18 PM
Oranoco's Avatar
Oranoco
I would recomend not bothering. Discs on the back of RS Turbo's is a bit pointless and typically give an over braked back end which can cause arse puckering moments. If the drums are ample to slow my friends 400bhp Fiesta down that's good enough for me
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Bransby
Sep 11, 2015 01:09 AM
Tony W
Sep 9, 2015 12:08 PM
cossirob
Sep 3, 2015 09:17 PM
