anyone made there own pressure washer?
Old Feb 17, 2012 | 12:35 PM
xr4x4rs's Avatar
xr4x4rs
Default anyone made there own pressure washer?
as title really
im getting very annoyed with these jet washs where the reels is coiled up and it just isnt long enough, so ive been looking into making my own, plus it will come in handy cleaning the drive and the decking in the garden
so far i can get a pump and an electric motor, hoses etc arnt a problem, but what im struggling is a control unit
i dont want the motor on all the time, so i need a control box so it turns it on when the trigger is pressed but carnt find anything on the net of what i need or how it would be wired up
i was thinking of just using a scrap jet wash circuits to power the motor but unsure if they have a transformer that takes teh voltage down where i need constant 240v supply
any ideas?
what i want to make is something like this
Old Feb 17, 2012 | 12:46 PM
fraser9764's Avatar
fraser9764
A simple pressure switch and relay will do the job.
Pressure switch should be set just above the working pressure
Old Feb 17, 2012 | 01:16 PM
xr4x4rs's Avatar
xr4x4rs
ok, so i need to work out what sort of presure the system would give, and put a pressure switch in the outlet pipe so when it goes below it turns the pump on
is that rite
Old Feb 17, 2012 | 04:56 PM
stu21t's Avatar
stu21t
Use a flow switch?
Old Feb 17, 2012 | 05:37 PM
xr4x4rs's Avatar
xr4x4rs
these pressure switch and flow valves are going over my head becuase there is so many different types
Old Feb 17, 2012 | 05:44 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Could you not just buy a long length of hose from a hose supplier and replace the coily hose on the existing jet washer?
Old Feb 17, 2012 | 05:47 PM
saph4be's Avatar
saph4be
That's what I did took my hose to local place and they re used the ends and made it 7 metres! Fits around car easy
Old Feb 17, 2012 | 05:49 PM
STAFFY OWNER
Sounds like a much easier and less costly option .
Old Feb 17, 2012 | 05:54 PM
xr4x4rs's Avatar
xr4x4rs
not that jet wash is pants anyhow and awkard to have it garage where this design can go up on the wall out the way, plus be more powerful
Old Feb 17, 2012 | 06:31 PM
whizzisat114's Avatar
whizzisat114
Most jetwash's are 1500 psi but there are 3000psi ones knocking about you should have a data plate on the pump?
Have you got the pump or motor?
or just batting idea's around?
Old Feb 17, 2012 | 06:55 PM
xr4x4rs's Avatar
xr4x4rs
just looking at the mo, got the pump on ebay which seems ok and can be used with either engine or electric motor, its the control side that i really need to know on what to to use once thats sorted i can start searching for stuff
Old Feb 17, 2012 | 07:21 PM
saph4be's Avatar
saph4be
Only cost me 21 quid too!
Old Feb 17, 2012 | 07:52 PM
mk2 escort boy's Avatar
mk2 escort boy
I use this type of pumps at work really simple things really you would be best of with a petrol powered one for home use as a commercial pump with elecly motor runs on 440volts and that's a 3.5hp motor or just by a decent lecky one if you have any probs pm me you address and I'll send you a parts catolog so you can build your own
Old Feb 17, 2012 | 08:29 PM
Retro Al's Avatar
Retro Al
RWD IS KING
Just buy a kranzle and a extension hose,you can have up to 30 meters of hose so more than enough
Old Feb 18, 2012 | 12:16 AM
stuboy's Avatar
stuboy
i was give one at work... blows the car away
Old Feb 21, 2012 | 07:35 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ah ha, found the thread!!
mate, have you sorted anything yet?
as i may have a solution
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
