cosworth inlet manifold were to get replacment vacum takeoffs in metal???
Feb 16, 2012 | 12:43 PM
as thread heading i want to get metal takeoffs to get rid of all the plastic ones anyone know were to get them???? cheers
Feb 16, 2012 | 01:06 PM
EBay - look under 6mm fuel pump union, npt thread
Feb 16, 2012 | 02:17 PM
re
Quote:
Originally Posted by
BRAMMER
do you now what size npt i would need???
Feb 16, 2012 | 02:30 PM
The vac lines are 3mm. I think they're 1/8, been ages since I bought some!
Feb 16, 2012 | 02:53 PM
These are what people are using and what i bought for mine and all vac lines go on even the small map sensor line
http://www.ebay.co.uk/itm/280640046481
Feb 16, 2012 | 03:10 PM
Surprised they fit Chris, but if they do, who cares
Mine were 1/8 to 3mm tail
Feb 16, 2012 | 03:17 PM
James90RS
Thats what i ideally wanted but couldn't find any at the time, i used the same as Ronni, Sonic and cossie 4i~TT38~turbosystems~spec R~dyno dynamic~did i mention TT38~Steve
Feb 16, 2012 | 03:40 PM
I order mine from Ian at CAM...........they were available in Anodised Alloy and at various angles.
Think I order 3 @ 90deg and 1 @ 45deg................pretty sure they were 1/8 NPT.
Cheers.
Feb 16, 2012 | 03:55 PM
Chris, just had a quick look on eBay - I didn't realise Demon Thieves did them
http://www.ebay.co.uk/itm/LMA-Vacuum...item2c629467b0
at Steve's long name...you blatently missed out AB07 on purpose, just so he'll get upset
Feb 16, 2012 | 03:57 PM
Hoogi
Cheers.
have you got a link to there site please
Feb 16, 2012 | 04:10 PM
James90RS
Will have to add air injectors and 6 degree beam soon as well
Steve
Feb 16, 2012 | 04:13 PM
Feb 16, 2012 | 04:32 PM
cossie4i_
These are mine, i think they look better than Chris's
Steve
Disagree, i think my Hart looks better than yours as it's powdercoated and not cheap rattle can finish
Steve what's that on the rear outlet?
Feb 16, 2012 | 04:42 PM
BRAMMER
You seen the price of rattle cans and clear laqur these days
Your inlet does look nice
Its for a vacum, because i still have a servo
Steve
Feb 16, 2012 | 05:48 PM
cossie4i_
Steve
And a split block
Steve
Feb 16, 2012 | 06:01 PM
Yeah but do you know what diff you've got?
they look the same as mine!
Feb 16, 2012 | 06:30 PM
cossie4i_
Steve
Forgot about that Steve
Feb 16, 2012 | 07:37 PM
Moonstone Steve
And who's 200 block is totally shafted at the moment?????
Feb 16, 2012 | 07:46 PM
90 degree ones i need any links
Feb 16, 2012 | 08:25 PM
andy escos
Replied to your PM Andy..............
Feb 16, 2012 | 08:28 PM
Graham............sorry just saw you note.
www.camauto.com .
Ian & Sam are the Guys............they should also be in the Goodridge Catalogue.
Hope that helps ?
Feb 16, 2012 | 08:37 PM
thanks ! on it
Feb 19, 2012 | 01:40 PM
Hoogi
thanks mate
May 31, 2016 09:28 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
Aug 14, 2015 07:29 AM
mick pearson
Aug 9, 2015 09:19 AM
