going over to cossie managemnet
what bits are involved
ive got a rough idea but when it comes to the loom does it need to be 2wd or 4wd one. same applies to the ecu L6 L8 etc etc. do certain ecu work only with certain looms
next part is the whole timing issue. ive seen some cars run a modified rst/cossie distrubter while others run it similiar to the efi set up. what CPS is needed presummed to be the best?
im total lost on whats needed
cheers
cheers
visit www.oddkiddcreations.co.uk or contact Jano_oddkidd on here for information on cosworth managaement
Russ Payne
Sep 25, 2015 08:29 PM
