Aux water hose kit - oil modine
Old Feb 1, 2012 | 04:41 PM
BRAMMER's Avatar
BRAMMER
Default Aux water hose kit - oil modine
My car has never had water running through the modine as long as i've had the car so i have no idea how it plumbs up so......
I need someone to show a pic of there's or explain the oil modine and cylinder head hoses
Old Feb 1, 2012 | 05:06 PM
nicksaph's Avatar
nicksaph
hello mate
there is a diagramme in this link mate
http://bbs.rsownersclub.co.uk/showthread.php?t=374684
the pipe from the front of the modine goes to the head and the pipe from the rear of the modine goes to the bottom heater matrix pipe
Old Feb 1, 2012 | 05:56 PM
BRAMMER's Avatar
BRAMMER
Originally Posted by nicksaph
hello mate
Many thanks Nick that is the info i'm after - now i need to decide which is the right hose to use
Old Feb 1, 2012 | 07:12 PM
BRAMMER's Avatar
BRAMMER
Right this is as far as i've got and all was going well until .......
The ones i have used on this side from the top matrix & the small stat housing - turbo
Then the rear modine - bottom matrix
Now then which of these fit's the front modine to head? and what is the other one for?
Old Feb 1, 2012 | 07:14 PM
cozzy jeff's Avatar
cozzy jeff
one on the left
Old Feb 1, 2012 | 07:15 PM
B13 JUS's Avatar
B13 JUS
the one of the left is your modine to head
not sure what the other is for
Old Feb 1, 2012 | 07:19 PM
BRAMMER's Avatar
BRAMMER
That doesn't fit it isn't long enough unless i turn the modine towards the rear but i thought they sat with the outlets perfectly vertical
Old Feb 1, 2012 | 07:38 PM
Thanasis's Avatar
Thanasis
this is the other one,
jpeg image hosting
Old Feb 1, 2012 | 07:54 PM
cozzy jeff's Avatar
cozzy jeff
jpeg image hosting
chris looking at this pic the hose you need is the 3rd one from the bottom
B13 JUS's Avatar
B13 JUS
just had a look at mine and on your pipe, on the straight section mine has a slight bend to get round the other pipe. if you know what i mean?
Old Feb 1, 2012 | 07:57 PM
B13 JUS's Avatar
B13 JUS
that pipe doesnt look right either.
the head fitting is higher than the modine fitting
that pipe looks like it fits onto the modine then drops down?
Old Feb 1, 2012 | 08:22 PM
nicksaph's Avatar
nicksaph
is the other one water pump to lower radiator pipe?
Old Feb 1, 2012 | 09:26 PM
cossiedad's Avatar
cossiedad
From memory and the pics above, I'd say the red arrowed hose is modine to heater - it runs down the block under the inlet manifold, round the back of the head where it crosses another hose (tight against bulkhead on saph) and then loops onto the heater pipe.
I believe the other modine hose is the 3rd one up, which goes to conenction by the coolant sensor under inlet and at back of head.
Both of these hoses are a complete pain in the arse to fit in situ if you have bolted on the complete inlet/throttlebody assembly!
Old Feb 1, 2012 | 09:36 PM
cossiedad's Avatar
cossiedad
@nicksaph the hose you refer to has another hose branching off halfway which goes to the rail across the bottom of the Rad, iirc. This hose is missing in the pics from Thanasis above, which makes me wonder if it's the correct kit ie 4wd in the pic.
Old Feb 1, 2012 | 09:45 PM
nicksaph's Avatar
nicksaph
that would make sence mate i am only familier with 4x4 and mine looke like the one in the picture
Old Feb 2, 2012 | 02:55 PM
BRAMMER's Avatar
BRAMMER
I managed to get the other pipe on but it's tight, i think i will have to angle the modine a little toward the rear, only slightly though - still have no idea what the other hose is as i have the water hoses which sort the pump etc as you buy them as the water kit and not the Aux kit - strange
Old Feb 2, 2012 | 03:36 PM
Gav Diamond's Avatar
Gav Diamond
Chris the other hose in your pic is from the header tank to the rad pipe I think
Old Feb 2, 2012 | 06:28 PM
BRAMMER's Avatar
BRAMMER
I did think that Gav as one of the ends is slightly bigger
jonfoc
16
Sep 11, 2018 05:35 PM
155lee
Oct 27, 2015 04:55 AM
dombanks
Sep 21, 2015 08:38 PM
Billy_RS
Sep 13, 2015 04:17 PM
hopper350
Sep 4, 2015 12:53 AM
