Transit 135 tdci engine loom
Old Jan 30, 2012 | 06:47 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Default Transit 135 tdci engine loom
Does anyone know how much a new engine wiring loom is for a 135 tdci transit, as mine has the usual problems where the loom has rubbed through at the multiplug, and on the vac pump, and is causing untold issues with the way it runs.
Any help much appreciated.
Old Jan 31, 2012 | 10:40 PM
DazC's Avatar
DazC
Last engine harness I got for a Transit was about Ł280 and they needed the numbers off the white tag on the old one.
Old Feb 1, 2012 | 08:12 AM
rsturbolee's Avatar
rsturbolee
my mate is breaking a 55 reg one of these and the looms still on it
Old Feb 1, 2012 | 08:31 PM
BRIGSPORT's Avatar
BRIGSPORT
Was hoping you would see this dazc.
Got quoted Ł320 from ford today for the loom!
The van has had 1 injector fitted, and after running on 3.5 cylinders for a while has come to a bit. Hopefully with a new fuel filter, some fuel treatment, and a good run out on saturday, it should stop going into limp mode.....................i hope!
Old Feb 1, 2012 | 09:18 PM
DazC's Avatar
DazC
That was for a 90ps model with an injector pump so 320 sounds abought right. Mine is a 137ps van too but it's only done 72k.
Whats wrong with it? What codes have you got out of it?
Old Feb 2, 2012 | 07:08 AM
BRIGSPORT's Avatar
BRIGSPORT
Po200, the wiring loom had rubbed through on the vac pump, and near the multi plug in front of the fuse box. It had been repaired there in the past.
Old Feb 2, 2012 | 10:44 PM
DazC's Avatar
DazC
Cut it back and repair it properly then put some protection on it.
Old Feb 3, 2012 | 07:12 AM
BRIGSPORT's Avatar
BRIGSPORT
Done all that. Van now goes into limp mode at around 60 mph, fuel pump related low/high pressure. Gonna change fuel filter and run a treatment through it and see what happens.
Old Feb 3, 2012 | 06:25 PM
DazC's Avatar
DazC
Could be the pressure reg valve but the pumps do give up on these occasionally. As you say though, check the restriction indicator on the fuel filter though as that will cause it.
Old Feb 3, 2012 | 07:29 PM
BRIGSPORT's Avatar
BRIGSPORT
Changed the fuel filter today, still the same. Comes up with p0251 and p1211 fault codes i think. New fuel pump being fitted next week.........................
Old Feb 3, 2012 | 07:31 PM
BRIGSPORT's Avatar
BRIGSPORT
Just to clarify, van is an 04 swb low roof 135 t330 with tailgate and twin side loaders, so a factory special order, with full ford service history. Done 108k, so due some pump/injector probs as standard!
Old Feb 3, 2012 | 08:44 PM
DazC's Avatar
DazC
It's not done too bad. They aren't too expensive from memory either.
My van was a special order and took 3 months to arrive. I ticked most of the extras boxes but opted for a standard body. I've also got the 135 but it's tuned too so it's pretty lively. Love it still.
Old Feb 4, 2012 | 08:24 AM
BRIGSPORT's Avatar
BRIGSPORT
Ł398 plus vat. We are gonna decat and remap it once fixed. Should go well.
Old Jan 12, 2016 | 09:44 AM
Florian's Avatar
Florian
Default Any luck with your Transit ?
I have similar problems and I have to start spending money ,i need a starting point though!
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
