Any alloy welders/fabricators want a small private job?
Old Jan 29, 2012 | 09:02 PM
stu21t's Avatar
stu21t
Default Any alloy welders/fabricators want a small private job?
i have an AH fabrications chargecooler its 4x4 inches square and i want both end tanks cut off and new ones welded on with 1 45degree outlet and 1 straight outlet both 60mm
i can cut off and make cardboard templates of this before sending up for you to copy
also i have an alloy rad with 2 inlet and outlet pipes all are 12mm. i would like them cut off and 1 25mm pipe put in its place.
(so in total, 4 (12mm) cut off and replaced with 2 (25mm))
also i have a header tank that i want 2 25mm outlet pipes welded to (i will drill the holes for placement)
and finally i have a 4x4 cosworth plenum cover that i would like the elbow cut off and turned 180degrees around, so the throttle body would face backwards.
(also thinking cut off the elbow totally and replace with a better flowing one, start with the old flange cut off, then a 70mm elbow off of there going into the plenum into a letter box shape.)
i can make a cardboard dummy for you to copy.
and then a throttle cable bracket to suit.
would you be interested in the work?
how much do you think it would be?
how long would it take?
and when could you do it?
Pm me
Old Feb 3, 2012 | 06:04 PM
dingla rs's Avatar
dingla rs
give the lad a email in my sig mate his work is mite and very cheap
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
`spotty
Sep 25, 2015 11:41 PM
IainRS1700T
Sep 25, 2015 06:44 AM
