Standard Rev counter in 2WD Saph
Old Jan 27, 2012 | 09:25 PM
andremarca's Avatar
andremarca
Default Standard Rev counter in 2WD Saph
Is there any reason for a 2.0GL Saph rev counter wouldn't work on my 2WD Cossie?
It reads about half what it should. before i take everything apart again and check the wire from the coil is there any reason for a stardard rev counter not to work on a Cossie with Dizzy?
Thanks
Old Jan 28, 2012 | 02:45 PM
martysmartie's Avatar
martysmartie
Yes as with any rev counter they are scaled, if you look at the bottom of the rev counter you should see as number, the correct Cosworth one has a C instead, denoteing it as such.
Martin
Old Jan 28, 2012 | 07:29 PM
andremarca's Avatar
andremarca
Thanks a lot Martin. It saves me from buying a 3rd one
FlashRS
13
Aug 31, 2015 06:02 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
