Group A genuine 4wd steel front crossmember
Old Jan 26, 2012 | 11:13 PM
markk's Avatar
markk
Default Group A genuine 4wd steel front crossmember
no longer required, adjustable tca positions, front ARB mount points etc removable section for quick rack changing
£480.00
Old Jan 27, 2012 | 07:51 AM
jacko996's Avatar
jacko996
£480.00
Hi mark
Do you have to run weld on chassis mounts for the engine with these?
Cheers dave
Old Jan 27, 2012 | 09:26 AM
M K's Avatar
M K
Yes you do Dave
Old Jan 27, 2012 | 11:54 AM
markk's Avatar
markk
as above
Old Jan 27, 2012 | 03:17 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Mark
I currently run a 4x4 cradle with 2wd running gear. Would the steel xmember you have still work like this with the obvious chassis engine mounts. Do you have a pic.
Old Jan 27, 2012 | 03:33 PM
markk's Avatar
markk
hi, yes it would fit, but you would have to have the correct rack mounts made to take the std rack.
i will put a pic up later.
Old Jan 27, 2012 | 07:36 PM
c20tbo's Avatar
c20tbo
Originally Posted by jacko996
Hi mark
Cheers dave
it could be modified to have the original engine mountings points on it, im having one made from MK like this, aswell as rack mounts for a 2wd rack.
Old Jan 28, 2012 | 09:38 PM
markk's Avatar
markk
only on the car
FlashRS
13
Aug 31, 2015 06:02 PM
C2 MAK
Aug 20, 2015 09:46 PM
Escortdriver1
Aug 13, 2015 05:55 PM
TIL13R
11
Aug 13, 2015 02:28 PM
RIB1122
Aug 12, 2015 08:51 PM
