inter cooler
Old Feb 23, 2005 | 10:32 AM
massey's Avatar
massey
Default inter cooler
hello ppl, can some body tell me what the diffrence is between a 2wd intercooler and 4wd intercooler on a saff cossie, do the 4wd fitt the 2 wd and what advantages is there if any
thanks for looking
Old Feb 23, 2005 | 10:40 AM
Dave McB's Avatar
Dave McB
4x4 cooler is slightly bigger than the 2wd one
Bigger means more air=more boost
Slight pain in the arse to fit to 2wd, but it will go in
Old Feb 23, 2005 | 04:57 PM
rapidcossie's Avatar
rapidcossie
you just have bend the top of the rad mountings down and mess around wi the rubber mounts.
got one for sale if you need it 50 quid plus pandp.
Old Feb 23, 2005 | 08:18 PM
Mr C's Avatar
Mr C
How you doing mate?? It will allow you to run a bit more boost than a standard 2wd before needing an RS500 I/cooler, I just had to shorten the inlet and outlet hoses a bit to make it fit my 2wd. Expect to pay £70 for one posted to your door.
gcfcos
59
Oct 6, 2015 05:04 PM
