skirt rivets
Old Jan 25, 2012 | 08:32 PM
Phil2002's Avatar
Phil2002
Default skirt rivets
Just had my car re painted and need to get some rivets to put the side skirts back what ones do people use as the the ones that came off had a plastic coating on them but seem to find any with this coating?
cheers,
Phil
Old Jan 25, 2012 | 08:49 PM
DAN400's Avatar
DAN400
i got mine from ford, expensive little buggers but,
im near sure i seen some on ebay last week, worth a try
Old Jan 25, 2012 | 09:01 PM
Phil2002's Avatar
Phil2002
i have looked on ebay but can only 3dr ones (guessing they need as many)
do you want to sell your number plate??
cheers,
Phil
Old Jan 25, 2012 | 09:05 PM
cosy trav's Avatar
cosy trav
I used ally pop rivets and painted the head .
Old Jan 25, 2012 | 09:10 PM
DAN400's Avatar
DAN400
lol i think there was a phil owed my car before,
he must ave put that reg on it cause it originally had an english reg
Old Jan 25, 2012 | 09:16 PM
martysmartie's Avatar
martysmartie
Exactly as said above, I got them from Ford but expensive, they have a black plastic head, where as my originals were painted.
You could get the rivets elsewhere MUCH cheaper, just get ones with the same size heads.
Martin
Old Jan 25, 2012 | 09:20 PM
Mark V8's Avatar
Mark V8
I bought some direct from my local Ford dealer in the past.
Dont' bother with my local dealer any more as these guys are really helpfull, give a discount and post the parts to you saving time and aggro
http://www.fordpartsuk.com/PARTSREQUEST.htm
Only takes a minute to fill the form in
Old Jan 25, 2012 | 09:25 PM
OldDan's Avatar
OldDan
You can buy black rivets.
Old Jan 25, 2012 | 10:05 PM
Paul_RS's Avatar
Paul_RS
You can still get coloured plastic coated rivits in selected colours from Ford. I've enough moonstone ones in the loft to do a couple of cars lol
Old Jan 25, 2012 | 10:17 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I used 5 mm black plastic Scrivets with the centre screws replaced with 3 mm stainless self tappers. These are easy to remove if you need to and unlike aluminium pop rivets, will not cause dissimilar metal corrosion between the aluminium and steel. I used them on the fitting strips as well as the skirts themselves. They are also dirt cheap.
The Scrivets look like this
http://media.jetpress.com/ProductDB/...600&height=600
Old Jan 25, 2012 | 10:39 PM
chrisa3's Avatar
chrisa3
Thats what i did. TBO, with the price difference, its probably cheaper to buy the black ones and touch them in with a brush.
Old Jan 28, 2012 | 03:49 PM
steventoon's Avatar
steventoon
where do you buy the scrivets from?
Old Jan 28, 2012 | 04:30 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I got them from ebay.
http://www.ebay.co.uk/itm/5mm-Screw-...#ht_2488wt_944
The screws came from ebay as well.
http://www.ebay.co.uk/itm/6-x-3-4-St...#ht_916wt_1177
No problem dealing with either supplier.
Old Jan 28, 2012 | 05:55 PM
Phil2002's Avatar
Phil2002
Nice one think i'm gonna go this route. i've replaced nearly all nuts and bolts with stainless now.
cheers,
Phil
Old Apr 29, 2012 | 01:25 PM
paulsheerin's Avatar
paulsheerin
Sorry to dig this up but do the dome headed self tappers not sit too high on the skirt?
Old Apr 29, 2012 | 04:40 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I have only used these on the RS option skirts, where all the rivets are hidden or only visible from underneath. Not Sure on the Cossie skirts.
Old Apr 29, 2012 | 06:02 PM
BRAMMER's Avatar
BRAMMER
Ford sell them
Old Apr 29, 2012 | 06:29 PM
paulsheerin
Any idea on the price? Someone said earlier on in the thread that theyre expensive for what they are
Old Apr 29, 2012 | 07:19 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
they range in price, i think moonstone ones are like 1.50 each
Old Apr 29, 2012 | 07:23 PM
paulsheerin
Ok cool. I'll be down in Ford during the week so i'll get some prices then. Thanks for the help
Last question for you guys, on the front section that attaches to the wing theres 2 rivets that hold the leading edge. but what way does it secure to the face of the wing? it looks like it slides down on to a clip of some type?
Old Apr 30, 2012 | 07:51 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
black plastic clip that rivets on
the black bits on top of the skirts
Old Apr 30, 2012 | 08:25 PM
BRAMMER's Avatar
BRAMMER
I know the ones for a 3dr are £1.86 each at our local dealer
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
155lee
Oct 24, 2015 11:11 AM
roomey
Sep 19, 2015 08:40 AM
