Cosworth exhaust manifold to elbow gasket
Old Jan 24, 2012 | 09:55 AM
andremarca's Avatar
andremarca
Default Cosworth exhaust manifold to elbow gasket
Is there any gasket that goes between the top elbow and the exhaust manifold on a 2wd? can't find one for sale.
Just had to take mine off and found there is no gasket there and had a light leek from it.
Old Jan 24, 2012 | 01:35 PM
andremarca's Avatar
andremarca
Anybody? need some help on this one...
Old Jan 24, 2012 | 01:39 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
no there isent a gasket just make shore the too faces are flat
Old Jan 24, 2012 | 03:17 PM
opposite lock's Avatar
opposite lock
Not sure if you meant something like this . http://www.burtonpower.com/sc785.html
Old Jan 26, 2012 | 08:41 PM
andremarca's Avatar
andremarca
Thanks but it's not that one.
Old Jan 26, 2012 | 08:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Nothing between mine.
Steve
Old Jan 27, 2012 | 04:33 PM
moonstone mike's Avatar
moonstone mike
No gasket and mines leaking!!!!!!!!
Old Jan 27, 2012 | 09:13 PM
andremarca's Avatar
andremarca
Mine was leaking too and had just been reassembled... to get both ends straight they asked about 130€.
I've researched a bit about this one and, apparently, copper melting point is above 1100şC and is flexible enough to be crushed and seal well.
I'll buy a 0,6mm sheet of copper and will do a gasket with it.
Old Jan 29, 2012 | 01:33 PM
funkyboozer's Avatar
funkyboozer
Mine didnt have one beween the manifold and turbo and was blowing, but is fine now i fitted one of these. (if this is the one you're talking about?)
http://www.ebay.co.uk/itm/COMETIC-GA...item45fc37bd70
Old Jan 29, 2012 | 01:44 PM
rog's Avatar
rog
Did it look like this?
No gasket, not a standard anyway, you get them between the turbo and manifold and they're usually more trouble than they're worth.
May 31, 2016 09:28 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
