Converting from cable to hydraulic clutch
Ive just built my forged zetec engine for my mk4 escort. Ive mounted the mtx75 Focus RS gearbox, and now need to convert to hydraulic clutch.
How do you lot recomend i do it? Was looking at motorsport peddle box's with master cylinders for brake and clutch, then i can get rid of all the old brake bar on the bulkhead and servo plus it would give me a lot more room. Obviously the downside is that i will have no servo, so a hard peddle, and the peddle box is around 500 quid?
Or... I could just use a clutch master cylinder off something else mabey? And would be the cheaper option. What would you do???
Cheers, Tom.
Cheers, Tom.
muz
Sep 30, 2015 08:29 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
