Which fuse for central locking??
Jan 20, 2012 | 08:34 PM
On a 2wd saph cossie?
Cheers Martin
Jan 20, 2012 | 08:43 PM
Jan 20, 2012 | 08:57 PM
Thank u mate I hope it's that as it just stopped working all together
Jan 20, 2012 | 09:27 PM
Check if your interior light works?
Martin
Jan 20, 2012 | 09:47 PM
Jan 21, 2012 | 03:40 PM
Put a new fuse in and ok for awhile then pops about 5hours later
Jan 21, 2012 | 04:57 PM
As interior light is on the same circuit, so that woulden't have worked either. I suspect you do, but do you have an aftermarket stereo?
Martin
Jan 21, 2012 | 05:06 PM
Yes it does only brought the car last weekend
first drive out today just this little problem
Jan 21, 2012 | 05:14 PM
I assume it blows when the car is left?
As a new owner you NEED to check your cooling fans work, thats if they haven't been rewired already.
Martin
Jan 21, 2012 | 05:48 PM
Yer had been rewired along with the fuel pump yes it when it's left
stephenb4506
33
Oct 2, 2015 06:25 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
