wideband lamba kits
Old Jan 20, 2012 | 08:23 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default wideband lamba kits
is there one better than the other iv got about 180 to spend on one, burton power do a couple of different ones and there are AEM and Innovate ones on ebay
cheers
Old Jan 20, 2012 | 10:06 PM
ASHCOSSIE's Avatar
ASHCOSSIE
like these ones
http://www.ebay.co.uk/itm/PLX-DM-6-A...ht_6806wt_1183
http://www.ebay.co.uk/itm/INNOVATE-M...ht_6631wt_1183
http://www.ebay.co.uk/itm/GENUINE-AE...ht_2259wt_1183
does any one know what is the best one of the above
cheers
Old Jan 20, 2012 | 10:20 PM
t16coupe's Avatar
t16coupe
few people i know have used the aem with no problems i used to have a innovate and it was ok but froze a couple of times
stevieturbo's Avatar
stevieturbo
C**t
http://www.ebay.co.uk/itm/Innovate-W...item35b07c5945
UK seller for the Innovate.
I cant comment on the other brands. But I bought one of the MTX from Richard above, and the quality is excellent. All wiring and connectors throughout are top notch. A far cry from their troublesome LC-1
Easy to wire up and looks tidy when installed. Comes with a white and black face for the dial so you can change to suit, and LCD display is orange.
If the PLX one does have the multifunction gauge as standard, then that would be quite good. Although you need to buy expensive controllers for each display you wish to add
Old Jan 20, 2012 | 10:34 PM
ASHCOSSIE's Avatar
ASHCOSSIE
or
http://www.ebay.co.uk/itm/KOSO-Wide-...0#ht_522wt_950
Old Jan 20, 2012 | 10:36 PM
ASHCOSSIE's Avatar
ASHCOSSIE
ideally would like one with a alarm if u go to lean ect
Old Jan 20, 2012 | 10:40 PM
stevieturbo
C**t
Impossible unless you're going to feed it with MAP, RPM, TPS etc signals.
going "lean" may only be a concern under certain circumstances. So no wideband only display is going to achieve that.
The other link looks ok, but there is no useful information on that advert. Just depends what sort of display you want really.
Old Jan 20, 2012 | 10:43 PM
stevieturbo
C**t
This Zeitronix may do what you want, but again, you'll need to supply it with more information.
http://www.zeitronix.com/Products/zavt/zavt.shtml
It's more expensive, and the alarm unit is a further cost.
Old Jan 20, 2012 | 10:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
throw another into the mix, VEMS, you can add an EGT to it then, and you can log that info too.
just a shame there is only one analogue output though.
never let me down, easy to setup once you find the online manual.
innovate is good kit too, had one briefly as a backup, never really installed it to test it thoroughly.
Old Jan 20, 2012 | 10:58 PM
stevieturbo
C**t
The old LC-1's were troublesome. I wouldnt recommend them. The new MTX is much better, plus as the gauge is the controller it still leaves 2 fully configurable analogue outputs
Old Jan 21, 2012 | 12:06 AM
t16coupe's Avatar
t16coupe
i think mine was the lc1 with the blue display gauge
Old Jan 21, 2012 | 01:13 AM
JFB Tech's Avatar
JFB Tech
Not entirely sane
I have the VEMs one, along with an EGT sensor, can't fault it. I have never used the datalogging though. It was called the A Fresh Tiny when I got mine, they only did it with the red display and silver bezel then. I think it is now called the Round and has a choice of display colour and bezel.
Old Jan 21, 2012 | 01:21 AM
ASHCOSSIE's Avatar
ASHCOSSIE
is there any uk dealers for them
Old Jan 21, 2012 | 08:48 AM
Jay,'s Avatar
Jay,
Sponsor
these are bloody brilliant ive use one for 8 years its that bloody reliable i buy new sensors just to check it is still reading correctly and it always is
uk dealer http://www.efi-parts.co.uk/
Old Jan 21, 2012 | 09:25 AM
SteveB's Avatar
SteveB
http://www.ebay.co.uk/itm/PLX-DM-6-A...d=308637092899
I've just bought this 1 this week..... 2 day delivery from Latvia
Old Jan 21, 2012 | 09:50 AM
R4N SS's Avatar
R4N SS
Ive got an AEM on mine. Will let u know when I fire the car up
Old Jan 21, 2012 | 10:33 AM
stevieturbo
C**t
it is annoying the way sellers state they are UK sellers shipping from UK. I can see why they do it though.
But Ive bought from xenonlv before and 100% excellent service from them. And their prices are hard to beat for any of the stuff they sell.
Old Jan 21, 2012 | 08:53 PM
ASHCOSSIE's Avatar
ASHCOSSIE
So in down to the aem or innovate one which best
Old Jan 21, 2012 | 08:59 PM
rsdene's Avatar
rsdene
No one considered the stack version?
Old Jan 21, 2012 | 09:05 PM
ASHCOSSIE's Avatar
ASHCOSSIE
How much is the stack one
Old Jan 21, 2012 | 09:22 PM
bigluke200's Avatar
bigluke200
Have an innovate one myself an have no complaints Also use the sensor to control my closed loop which it does with no trouble.
Old Jan 21, 2012 | 10:57 PM
stevieturbo
C**t
Entirely up to you. It would be hard to say one is better than the other.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
