Escort cosworth uprated front driveshafts
Old Jan 20, 2012 | 03:30 PM
kosmic's Avatar
kosmic
Default Escort cosworth uprated front driveshafts
Hi
Is this good stuff and will it fit Escorth cosworth 4x4 for both sites?
http://www.ebay.co.uk/itm/SIERRA-ESC...item20b9434c56
Regards
Bo
Old Jan 20, 2012 | 03:39 PM
James @ M Developments.'s Avatar
Hardly "uprated" though,
They are just XR4x4 shafts which are 10mm longer than the cosworth items.
IMO they are not the answer to the problem, and when i tried a set of 10mm longer shafts in my saff, i couldnt go around corners
Standard shafts, with uprated engine mounts works much better.
Old Jan 21, 2012 | 08:56 PM
000's Avatar
000
Originally Posted by kosmic
Yes it fits both sides, I think GGR ones are cheaper.
Old Jan 23, 2012 | 10:39 AM
ECOS95's Avatar
ECOS95
GGR want £260.00 each. I've bought a set from Duncan just need to get round to fitting them.
Old Jan 23, 2012 | 05:32 PM
porterste's Avatar
porterste
The longer shafts are 4x4 ones and are better if you are running adjustable TCAs to get neg camber. To get it to turn in you need compression struts and put loads of castor on
Vincereese
Jun 1, 2023 09:14 AM
James Porter
Aug 26, 2015 10:51 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
