plastic welders under £100
Old Jan 18, 2012 | 08:38 PM
phil robson's Avatar
phil robson
Default plastic welders under £100
there a few on ebay but not sure wot they like? anyone recomend any or had experience with them? cheers
Old Jan 18, 2012 | 08:51 PM
andi-p's Avatar
andi-p
If you manage to get one would you be intrested in welding a small crack in a bumper?
Old Jan 18, 2012 | 09:03 PM
phil robson
would have to get some practice first, my mondeo had been written off and im on fixing it but most bumpers are cracked so fancy having a go meself
Old Jan 18, 2012 | 09:11 PM
andi-p's Avatar
andi-p
My wife bumped her Galaxy and the rear bumper has a 2" crack. I didn't want to buy a plastic weldling kit for the little crack.
Old Jan 18, 2012 | 09:39 PM
dingla rs's Avatar
dingla rs
depends on the kinda plastic it is ,as if its thermasetting plastic you can welded it back to gether with a soldering iron ,
Old Jan 18, 2012 | 10:00 PM
BigErn's Avatar
BigErn
We plastic weld bumpers etc with soldering iron as above..... it thermosetting plastic that cannot be welded iirc. Mondeo's have thermosetting bumpers if from the top of my head and cant be welded that way.
Old Jan 18, 2012 | 10:13 PM
andi-p's Avatar
andi-p
Is there a way to identify them before taking a heat source to the bumper.
Old Jan 18, 2012 | 10:15 PM
phil robson
i wiil have a look to see what sort of plastic it is
Old Jan 18, 2012 | 10:17 PM
phil robson
there is usually a code inside the bumper saying abs or pp or teo or summit like that?? then u need a plastic welding rod of the same plastic as well so i am led to believe?
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
Steve Escos
Oct 1, 2015 06:57 AM
Brian
Sep 11, 2015 08:06 AM
