Cossie 4x4 After-Market Exhaust Manifold ?
Old Jan 18, 2012 | 08:09 PM
Hoogi's Avatar
Hoogi
Default Cossie 4x4 After-Market Exhaust Manifold ?
Anyone using an After-Market 4x4 Stainless Exhaust Manifold ?
Is there a preferred option - I don't have enough room for a 2WD item.
Seen the Italian "Oppi" one on eBay which gives you options on Material Spec and Tube Dia. but that just lost me
Any advise would be great
Many thanks...........
Old Jan 18, 2012 | 08:11 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
there were some doing the rounds that caught the engine mount and needed modified to fit so be carefull, think they may have been XS Power?
Sean.
Old Jan 18, 2012 | 08:15 PM
damien roe's Avatar
damien roe
oplinger motorsport is on here send him a pm explaining your problem let him decide the size of it etc
Old Jan 19, 2012 | 06:06 PM
Hoogi's Avatar
Hoogi
Thanks Gents
Old Jan 19, 2012 | 06:53 PM
andy escos's Avatar
andy escos
frofix do a manifold specifically for the mk2 escort but its not cheap
http://www.ebay.co.uk/itm/Ford-escor...#ht_2040wt_698
MT MOTORSPORT on here has a nice wrc one that would fit
http://mt-motorsport.com/marko/index...&products_id=7
Old Jan 19, 2012 | 07:05 PM
TimC's Avatar
TimC
A lad local to me has a Nortech item on his Escos, also Primary Designs make some but they aint cheap, especially if you up the spec to inconel.
Old Jan 19, 2012 | 07:07 PM
TimC's Avatar
TimC
Or despite him being like a broken record when it comes to Zetecs and Ian Howell, pm zetecboostboy522hp or whatever his user name is (Paul Cheshire is his real name), he seems to be pretty handy at making manifolds too.
Old Jan 19, 2012 | 07:10 PM
MAD Ade's Avatar
MAD Ade
Mmm, my Primary Designs inconel one was 3 grand
Old Jan 19, 2012 | 07:14 PM
MAD Ade's Avatar
MAD Ade
What power are you looking for? Anything below 600 brake I wouldn't bother, the 2wd is fine, especially if you get an external waste gate set up and adapted elbow, you can get this bit from Reyland Motorsport.
Old Jan 19, 2012 | 08:51 PM
botters's Avatar
botters
competant bodger
allthough yes you are technically correct, sureley a proper 4 branch matched length primary manifold can be beneficial in other ways even on lower powered cars like aiding spool up, better gas speed etc... allthough as you say the standerd one isnt really a restriction until higher hp is required
Old Jan 19, 2012 | 09:02 PM
andy escos's Avatar
andy escos
As he said in his first post he do not have the room as its in a mk2 escort
Old Jan 19, 2012 | 10:32 PM
JHS's Avatar
JHS
China product from a bedroom trader, I wouldnt spend a penny on "his" products.
Old Jan 20, 2012 | 10:31 AM
turbospud1's Avatar
turbospud1
hoggi,ive been through the same process and ended up doing my own,ive still got the frame for sizing it on but it still takes ages to make.
the 4into1 does rev freer but the biggest advantage is its 12kgs lighter and it fits
Old Jan 20, 2012 | 11:33 AM
Hoogi's Avatar
Hoogi
Think I've seen you Car/manifold either on another Forum or at the Lakes Tour.
Can't quite remember apart from it looking real good.
I've a very good Mate who's a great welder so maybe that's a option for me ?
Also just looked at the Opplinger item on ebay which looks OK.
Old Jan 20, 2012 | 11:44 AM
DAN400's Avatar
DAN400
just stay away from the xspower ones ,
my mate built a cossie mk 2 for a guy and fitted one,
had it off more times than it was on getting it welded,and was always blowing out, pure scrap,
ended up putting a std 2wd item on, but it was tight for room.
when it comes to aftermarket manifolds imo you really have to spend good money to get one thats not going to break your heart
Old Jan 20, 2012 | 01:08 PM
turbospud1's Avatar
turbospud1
from the turbosite as ive deleted the pics,turned out no bad and still no cracks or blowout,if i was doing it again i would get someone to cnc the flanges,takes ages doing it by hand
Old Jan 20, 2012 | 05:48 PM
Hoogi's Avatar
Hoogi
Now that's nice.............very, very nice.
Old Nov 24, 2012 | 03:55 AM
Sod's Avatar
Sod
Hoogi - did you end up finding one that would fit?
I am putting a YB into a Mk1 Cortina and have got the same issue so interested to know how you got on.
Old Nov 24, 2012 | 06:02 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Just use a 4x4 manifold, thats what i used in my MKV Cortina
Steve
Old Nov 26, 2012 | 07:17 AM
Sod's Avatar
Sod
Is the 4x4 manifold a fair bit smaller?
I'd imagine the MkV engine bay is a fair bit bigger than the Mk1
Old Nov 26, 2012 | 07:22 AM
The Youth.'s Avatar
The Youth.
yes its's about 1/3 of the size of a 2wd manifold
steve
Old Nov 26, 2012 | 07:41 AM
jamie956's Avatar
jamie956
4x4 manifold should fit no problem,
Here's a link to a mk1 build with plenty of pictures,
http://www.turbosport.co.uk/showthre...ed-Mk1-Cortina
Old Nov 26, 2012 | 08:27 AM
Sod's Avatar
Sod
Ok thanks for the info!
Old Nov 26, 2012 | 08:39 AM
v man's Avatar
v man
Zee Germans are coming
Pm crazycage
That's all you need to do
Old Nov 26, 2012 | 08:46 AM
botters's Avatar
botters
competant bodger
strange problem this too as my mk2 escort has a 2wd manifold and fits fine within at least an inch or more
clearance on inner wing
Old Nov 26, 2012 | 10:52 AM
DazC's Avatar
DazC
To be fair Botters, there is nothing else but the engine and manifold in your engine bay!!
Old Nov 26, 2012 | 10:56 AM
botters's Avatar
botters
competant bodger
true but there is nothing else that goes in the way on that side of the engine bay and its on pinto engine mounts which have put the engine 20mm over to the o/s for some reason so when its centralised as it should be there will be even more room!
May 31, 2016 09:28 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
Old ford
Jul 31, 2015 06:50 AM
