difficult gear change 4x4
Old Jan 18, 2012 | 06:28 PM
steventoon's Avatar
steventoon
Default difficult gear change 4x4
I'm having problems with the gearbox when coming down the gears, specifically getting it to change down into first and second.
Anybody got any ideas?
Steve
Old Jan 18, 2012 | 07:02 PM
gouch1's Avatar
gouch1
Manual or auto what make
Old Jan 18, 2012 | 07:09 PM
steventoon's Avatar
steventoon
Hi
4x4 Sapphire Cosworth manual
Old Jan 19, 2012 | 02:29 AM
Rob Virgo's Avatar
Rob Virgo
Had a similar problem and was looking out for a replacement box until the clutch cable sniped, fitted a new one from Matt Lewis and sorted issue., cable must have been stretched and not disengaging clutch fully..
Old Jan 19, 2012 | 06:25 PM
steventoon's Avatar
steventoon
Thanks Rob, I'll take a look at the cable. It seemed to get worse when the engine was hot!
Where in Cork are you? I'm probably going back to the in laws in clonakilty this year.
Steve
Old Jan 19, 2012 | 06:51 PM
dojj's Avatar
dojj
Resident Wrestling Legend
In the order of difficulty I'd do this
Adjust ratchet in the pedal assembly
Clutch cable
Ratchet swap in the pedal assembly
Cradle bushes/linkage
Box
Old Jan 19, 2012 | 06:54 PM
dojj's Avatar
dojj
Also, if you get as far as taking the pedal box out make sure it's still straight as I've had one that had twisted and when input my foot on the pedal the twist in the pedal box was causing the cable to move without moving he clutch
Old Jan 19, 2012 | 07:36 PM
steventoon's Avatar
steventoon
Thanks dojj, I ll take a look at the weekend.
Steve
Old Jan 20, 2012 | 04:23 AM
Rob Virgo's Avatar
Rob Virgo
Close to city Steve , clons a good spot ESP around west cork rally weekend....lol
Old Jan 20, 2012 | 12:23 PM
martysmartie's Avatar
martysmartie
Don't know on 4x4 but on 2WD (Borg Warner box) a common issue with downshifting can be down to worn "Bulk rings"
Martin
Old Jan 20, 2012 | 01:11 PM
rog's Avatar
rog
I'd check and change the oil too for all it costs.
Old Jan 20, 2012 | 04:39 PM
Paul_RS's Avatar
Paul_RS
I'd be looking at the clutch/clutch cable first. As mentioned when i had a dodgy cab;e it lead to crap chages. I also have a broken AP clutch plate that gave the smae symptoms
Old Jan 24, 2012 | 07:44 PM
steventoon's Avatar
steventoon
Thanks Paul, I've had a quick look, it seems the outer sheath of the clutch cable has melted a little due to the way it was routed. I'll go in to Woodfords and get a new one.
Thanks for the replies,
Steve
rex647
Mar 6, 2022 06:20 AM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
