how much to convert a 4x4 saph to 2wd
Old Jan 18, 2012 | 06:25 PM
ginner's Avatar
ginner
Default how much to convert a 4x4 saph to 2wd
As above what parts are needed apart from the obvious and a rough cost please
Old Jan 18, 2012 | 06:28 PM
thebronze's Avatar
thebronze
Blag Master
Why?? Just wondering
Old Jan 18, 2012 | 06:50 PM
ginner's Avatar
ginner
because tarquin ive found a saph which is perfect.mint bodywork good power the only problem is its 4x4
Old Jan 18, 2012 | 07:16 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Cracking question!
i will never own a 4x4 cosworth, if i do i break them, i built an escos, it was rwd too.
Answer to yer question, depends how far you wanna go?
front suspension/sump/rack/cradle/UJ`s are all different, you can swop the sump and use some nackered outer CV`s on the 4x4 setup hubs which is fine and creates no more drag than 2wd.
gearbox mount, you will have to made a midified one but no big deal.
speedo cable different aswell i think, not 100% on that one.
rear end, keep 4x4 brakes or full axle if you want but 7" little less reliable than 7.5" but not a lot! upto stg3 should be fine aslong as you dont smash the granny out of it in carparks and away from the lights on the limmiter and sidestepping the clutch!
prop will need to be T5 tho, unless you use MT75 RWD (also fine! i use scorpio hyd clutch ones for this on customers cars, again dont fcukin abuse them lol)
so depends if you want it 100% 2wd cos T5/7.5inch,
look on ebay for current buying and selling prices.
Old Jan 18, 2012 | 08:50 PM
Turbosimpsons's Avatar
Turbosimpsons
About 1k.
Old Jan 18, 2012 | 09:30 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
Ginner, may I ask why 4x4 is a problem? Obviously it;s your car and your choice, but is there a specific issue with the saph's 4x4 system or do you just prefer rwd?
Old Jan 18, 2012 | 09:34 PM
Rsmat's Avatar
Rsmat
He wants a mans toy...,
Give us a bell at weekend mark.
Old Jan 18, 2012 | 09:38 PM
Darylc.'s Avatar
Darylc.
49cc superbike!
Are the 4x4's that boring then?
Old Jan 18, 2012 | 09:46 PM
Rsmat's Avatar
Rsmat
Nah not really IMO... Can still get one side ways easy enough.
Old Jan 18, 2012 | 10:01 PM
thebronze's Avatar
thebronze
Blag Master
I'd kill to have a Saph 4x4... never got them or any other cossie's over here
Old Jan 20, 2012 | 07:00 AM
ginner's Avatar
ginner
NotHing wrong With 4x4 as I've owned a 4x4 Saph and currently have a escos , but it costs ure left bollock to get usable big power with them , gearbox,diffs etc.plus 2 wd is so much more fun. And that's what cossies are all about.
Ill give u a bell saturday matt
Old Jan 20, 2012 | 08:43 AM
Rsmat's Avatar
Rsmat
Ok pal will do mate.
Old Jan 20, 2012 | 08:54 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
is the scorpio hydraulic clutch compatable with all mt75 boxes then??
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
