Crank Position Sensor Gap - Autronic SM4?
Does anyone know what the gap should be on a Crank Position Sensor for Autronic SM4? Ive PM'd Mark Shead, but Im hoping to fit the new sensor tomorrow and get the car running again and am unsure if he will see/read the PM.
I had it running the other day, but was hard to start and was gapped around 0.6mm. We changed the gap to 0.8mm and the car just keeps turning over. I gapped it closer, but proper miss judged it and the lugs hit the sensor, hence Ive got a new sensor to be safe.
Any help please guys, really want the car running so I can bleed the power steering/coolant and see if the exhaust is blowing.
Has it run on Autronic before?
If not you have to remove 2 lugs from the bottom pulley (if a std type with 4 lugs), and you have to remove something the phase sensor picks up too I think
mine is std gap although mark might have changed it when mapping.. the other is remove a lobe inside the dizzy but as yours is already running autronics it must be done already..
i m on sm2 and my crank sensor gap is just the same as it was on the level 6,
i also had to offset my pulley by 30 degrees (i think) not sure if that needs done on the sm4
Thanks everyone, Mark has given me the info on another forum
Mine has run Autronics for a while, but Ive converted to 2wd and changed the sumps, so the CPS needs to be gapped again
This is why I love SM4 on the 1.09 firmwear, the data logger lets you see every tooth the sensor does or doesnt see.
Makes you really lazy, bet Mark hates getting the older ones back in for diagnosis now, lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
