Gearing the bike...oh dear
Old Jan 18, 2012 | 02:06 PM
StephTell's Avatar
StephTell
Default Gearing the bike...oh dear
LOL
Was after new sprockets for the turbo'd Katana but the tallest gearing available off the shelf gives me nearly 199 mph at the limiter
Trouble is that with around 250 to 300 BHP at the rearwheel it would easily slam into said limiter...and it would still be trying to spit me off at silly speeds!!!
Old Jan 18, 2012 | 02:55 PM
GARETH T's Avatar
GARETH T
Bit off the wall think, bigger rear wheel?
Old Jan 18, 2012 | 06:20 PM
Deano's Avatar
Deano
Custom made sprocket ? Look at the size used for stunters surely someone could knock you some up
Old Jan 18, 2012 | 06:31 PM
GARETH T's Avatar
GARETH T
What size front and rear are you using?
Old Jan 18, 2012 | 06:41 PM
MAD Ade's Avatar
MAD Ade
Dependant on engine spec, could you not raise the rev limit? Just a thought...
Old Jan 18, 2012 | 07:41 PM
stevieturbo's Avatar
stevieturbo
C**t
Surely getting a rear sprocket with less teeth is easy ? Or front with more teeth ?
Old Jan 19, 2012 | 07:56 AM
StephTell's Avatar
StephTell
I'm running 17" front and rear, larger rearwheel isn't an option because tyresize limits wheelchoice.
Most stunters I know use ally sprockets, not such a good idea when running between 250 and 300 HP at the wheel I don't think...
The tallest gearing that is available of the shelf gives the 199 at the limiter, and that is with the smallest front and rear combo for this bike.
Í'd have to look into some custom dragrace items I think...?
raising the revlimit isn't really an option, it's a high as it'll go on this spec
It's a 1206 cc oilcooled four, tough as nails but quite oldschool!
Old Jan 19, 2012 | 09:16 AM
stevieturbo
C**t
Surely a custom sprocket made from a suitable hard material should be easy enough made these days ?
Bound to be places that would be a simple task ?
Old Jan 19, 2012 | 11:03 AM
Deano's Avatar
Deano
Was going to say it wouldnt be difficult getting one made up I dont think
Old Jan 19, 2012 | 03:44 PM
madsi's Avatar
madsi
b and c express made me some renthal sprockets up in the sizes i wanted
The Youth.
Sep 30, 2015 09:59 PM
DavidK
Sep 27, 2015 02:55 PM
