AAGH help with brake bleeding
Old Jan 18, 2012 | 01:02 PM
ajuk's Avatar
ajuk
Default AAGH help with brake bleeding
I bought a basic kit with a small plastic tube and one way valve to bleed my brakes on my MKIV fiesta and now I have no brakes at all is this normal will this correct itself after the rears have also been done, or has something gone wrong?
Old Jan 18, 2012 | 01:15 PM
Jim Galbally's Avatar
Jim Galbally
youve done it wrong, you shoudnt make it WORSE.
those 1 way valve things are crap youve probably just not bled them properly and let a load of air in. find a friend to do it with you or buy an ezibleed
Old Jan 18, 2012 | 01:17 PM
r06ert's Avatar
r06ert
sounds like something has gone wrong
you should start with the rears first, starting from the furthest away from the brake fluid reservoir
Old Jan 18, 2012 | 01:38 PM
r.s.2000 ginger's Avatar
r.s.2000 ginger
Yer thats the way i have always done it the ferthest away first and i wouldnt bother with them kits do it the old way one in the car and the other on the spaner.
Old Jan 18, 2012 | 02:14 PM
ajuk's Avatar
ajuk
OK acording to the Haynes manual it said start at the left front. I managed to get the brakes working again with the help of an assistant, but they feel no better than before. I couldn't do the rears.
Old Jan 18, 2012 | 02:35 PM
r06ert's Avatar
r06ert
why cant you do the rears?
there might be only one at the rear and it will be at the top of the wheel rather than the bottom
rears will not make much difference as around 70% is applied to the front
if the old brake fluid is rotten it may take a while to bleed it all through until the new fluid has filled up the brake pipe, you should notice a difference in the colour for one
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
