This car just never seems water tight!
Old Jan 17, 2012 | 02:36 PM
Fordmad!'s Avatar
Fordmad!
Default This car just never seems water tight!
Ive had no end of trouble keeping water out but always seems to find a way in!
Cars an mk4 xr3i cab and so far ive had water coming through
Back lights, had to silicone up
Rear bumper, had to also silicone up
Battery tray (was rotten, now repaired)
Fusebox, silicone did the trick here as it was coming through the hole
I now have it coming in at the door seals i think. Just noticed it on the drivers side. Was thinking of taking the insulation out and not bothering with it, anyone else do this?
Just don't want the floor going as its as clean as anything inside at the moment!
Old Jan 17, 2012 | 04:13 PM
Fordmad!'s Avatar
Fordmad!
Anyone not have the same problems...?
Old Jan 17, 2012 | 04:25 PM
Chopshop85's Avatar
Chopshop85
Mine started to get a slightly damp floor once. Turned out to be a little bit of rot where the footwell met the wing/door hinges.
Just wip the carpet up and have a look.
Old Jan 17, 2012 | 04:27 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
poorly fitted roofs leake every where
when teh doors are shut the glass should sit under the seal
water can get in thru the sills if the drains are blocked but water gets in
to fix it for sure take the seats out take the carpet and the insulation out and dust over it with talc and wait til it rains to see where it comes thru
could be rubbers, floor seams or rot, bulk head gromets, 1/4 windows
many many things
j.hammond1
30
Oct 31, 2021 05:28 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
john_3.0s
Aug 15, 2015 07:44 AM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
