diff ratio wheel size
Old Jan 16, 2012 | 06:22 PM
bly's Avatar
bly
Default diff ratio wheel size
Can anyone help ,some of you might know i am in middle or at the begining of building impreza powerd Mk1 escort , i am going to be
useing a Sti v3 Type Ra engine and gearbox ,
they run a 4.44.1 diff ratio on 16inch wheels cams on v3 Type Ra
rev to 8400 rpm
i will be useing Atlas Axle with 8x13 wheels
does anyone know what diff ratio i will need with the smaller 13 inch wheels to get same ratio as ith 16inch
thanks
Old Jan 16, 2012 | 06:27 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Wheels size means nothing need tyres size on both wheels. 5th gear ratio also required then its easy.
Old Jan 16, 2012 | 06:58 PM
bly's Avatar
bly
on gearbox chart 5th = 0.825
impreza wheels 205/50x16
escort wheels 215/50x13
Old Jan 16, 2012 | 07:10 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
The Imprezza would give 19.55mph/1000rpm in 5th so 8400rpm = 164.2mph.
To get exactly the same in the Escort would require a 3.96 diff or as close to that as possible.
Cheers Rod
Old Jan 16, 2012 | 07:58 PM
bly's Avatar
bly
ok thanks, 3.9 in atlas are hard to find was thinking 3.75 which are easey to find and mybe try to get a 40-45 x13 tyre
Old Jan 16, 2012 | 10:14 PM
stevieturbo's Avatar
stevieturbo
C**t
What sort of overall gearing do you want ?
Even on the Subaru with the 4.44, it is horrifically short gearing.
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
