Mk1 Focus Water Leak, Whats Underneath The Rear Bumper?
My 2002 Focus hatch has developed a water leak on the rear drivers side. After lots of messing about removing the light and sealing with silicone I started messing about with a watering can. When I pour water with the hatch open near the right side of the car along where the bumper meets rear panel. See picture with arrow below:
It leaks in a small amount inside the hatch in this area, see arrow:
There is a bit of a build up of crap where the bumper meets the rear panel so I have a bad feeling that it maybe has a hole in it, although there is little rust on the rest of the car. I just wondered before I remove the bumper are there any grommets under it in the vicinity of the leak. If not I may just bite the bullet and take it somewhere to get welded as it is probably a hole. Thanks for any help.
I believe that I have fixed this now, well a temporary fix. The water appears to be getting through a sealant that is sealing a gap more or less where the arrow is just below the bumper line. I think that the sealer is called Tiger seal or something. Anyway I do not have any of that so just had to use loads of silicone sealant as a temporary fix. I am guessing that this is not the best stuff to use and will eventually come off. So I will probably take the bumper of again in the near future and remove the silicone sealer and more of the tiger seal and re-seal it and then paint over it. Just thought I would post the findings just in-case anybody else has the same problem.
track.focus'd
Aug 12, 2015 05:53 PM
